dfischer(at)iserv.net Guest
Posted: Tue Oct 17, 2006 7:22 pm Post subject: Wing skin oil-canning |
I just finished riveting on the top LH wing skins and I noticed one of the
"squares" was indented and would "oil can" when pushed from the inside.
The square is bounded by two ribs (the fourth and fifth from the tip), the
forward spar, and the "J"stringer. It is the fourth bay inboard from the
tip (RV-9). All other skin "squares" are tight/neutral. Any ideas (other
than drilling out every rivet in the skin) to address this issue? I was
thinking of drilling out the rivets around the square to allow the skin to
average out between three squares and re-rivet. Just wanted to see if
anyone else has run into this problem and worked out a solution. Other
than this the skin is perfect (well, pretty good at least). Thanks in
advance for the help!
Doug Fischer
Jenison, MI
RV-9A Wings
| - The Matronics RV9-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV9-List |
dthomas773(at)sbcglobal.n Guest
Posted: Tue Oct 17, 2006 8:28 pm Post subject: Wing skin oil-canning |
Don't worry about it. If it doesn't move more than
1/8 inch you don't need to worry. Mine does that and
after 300 hours it's OK.
Dennis THomas
a solution. Other
least). Thanks in
Doug Fischer
Jenison, MI
RV-9A Wings
sa300(at)uniserve.com Guest
Posted: Tue Oct 17, 2006 9:56 pm Post subject: Wing skin oil-canning |
Don't worry about it. A lot of metal planes have oil canning in them, the wing panels upper and lower or the fuselage, and all control surfaces. Move on and continue building. You will only make a big mess if you try to get rid of it.
dthomas773(at)sbcglobal.net (dthomas773(at)sbcglobal.net) wrote: [quote] Quote: | --> RV9-List message posted by: <dthomas773(at)sbcglobal.net> (dthomas773(at)sbcglobal.net)
Dennis THomas
a solution. Other
least). Thanks in
Doug Fischer
Jenison, MI
RV-9A Wings
| [b]
noel(at)blueskyaviation.n Guest
Posted: Wed Oct 18, 2006 6:36 am Post subject: Wing skin oil-canning |
It’s a real shocker to see that after completing a wing. I had it on an RV-10 I built. After flying I was able to overlook it some what and enjoy the ride.
Noel
RV-9A (for sale)
From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Doug Fischer
Sent: Tuesday, October 17, 2006 9:22 PM
To: RV-9 Matronics List; RV Matronics List
Subject: Wing skin oil-canning
Doug Fischer
Jenison, MI
RV-9A Wings
Quote: | http://www.matronics.com/Navigator?RV9-List | 01234567890123
chenoweth(at)gwi.net Guest
Posted: Fri Oct 20, 2006 3:58 am Post subject: Wing skin oil-canning |
Doug,
I don't have anything to add to what you've gotten from this and the RV list. But, here's a bit of warning about what may be a common oil can problem with the fuselage. The bay between bulkheads 707 and 708 on my 9 was really very bad - lots of slack in the skin. My RV7A (flying) neighbor has the same problem. He's living with his (I gather it's quite startling when it oil cans in flight). I asked Van's about putting a J stringer in. They said no problem and that I didn't have to attach it to the bulkheads. Someone on the List cautioned about cracking skin if the stiffener wasn't tied to the bulkheads so I did that. I put in two due to the difficulty of getting one in the exact middle. Problem solved.
Bill
Albion, Maine
About to rivet center section to tail cone.
Posted: Fri Oct 20, 2006 6:44 am Post subject: Wing skin oil-canning |
One thing that you do not want to do while riveting skins on is to use an incandescent trouble light. The heat generated from the light bulb is enough to expand the skin and this too can cause a loose skin. Found this out a few planes ago.
Chenoweth wrote: [quote] Doug,
Bill
Albion, Maine
Quote: | ----- Original Message -----
To: RV-9 Matronics List (rv9-list(at)matronics.com) ; RV Matronics List (rv-list(at)matronics.com)
Sent: Tuesday, October 17, 2006 11:21 PM
Doug Fischer
Jenison, MI
RV-9A Wings
Posted: Fri Oct 20, 2006 11:43 am Post subject: Wing skin oil-canning |
I don't remember if I used my incandescent or my fluorescent (which actually generates a surprising amount of heat) but it might well have been the root of my problem.
Thanks for the tip.
Bill
Posted: Fri Oct 20, 2006 1:30 pm Post subject: Wing skin oil-canning |
Quote: | Definitely not the issue here - All the lighting in the build area is
flourescent.
[quote] actually generates a surprising amount of heat) but it might well have
Thanks for the tip.
Bill
aurbo(at)ak.net Guest
Posted: Fri Oct 20, 2006 3:59 pm Post subject: Wing skin oil-canning |
Hi,
Don't drill out the oil can skin, you are likely to do more damage than good. I have heard of some folks just pro-sealing in some J-stringers where the oil canning takes place.
Mike Ice
Electrical
RV-9
Anchorage, Alaska
Posted: Sat Oct 21, 2006 4:08 pm Post subject: Wing skin oil-canning |
Mike,
Not sure what you mean by "drilling out". I riveted my two Js into the
fuselage bay and that has certainly cured the oil can problem but, of
course, what will happen when the plane is flying remains to be seen.
Bill
Posted: Sat Oct 21, 2006 5:38 pm Post subject: Wing skin oil-canning |
Bill,
At the beginning of this tread, Mr. Fischer was wondering if he should " I
was
average out between three squares and re-rivet".
Sorry for the confusion.
Mike
