New battery optionNew battery option/W&B
tompkinsl(at)integra.net
PostPosted: Tue Oct 17, 2006 3:15 pm    Post subject: New battery optionNew battery option/W&B Reply with quote
I have done numerous preliminary W&B calculations and reached a similar conclusion. Occupant weight in an RV-7 is aft of the empty CG.
My solution will be to hang a Hartzell C/S prop on the nose. At least the 20 Lbs. of ballast on the nose will provide an advantage in short field and climb capability.
Larry Tompkins
360 896-2925
