CrownLJ(at)verizon.net Guest
Posted: Tue Oct 17, 2006 4:54 am Post subject: Mixing brands |
I have heard before that it is not wise to mix brands of oil in an
injection system without sucking the old out and changing the filter.
If true, why is this? I poured some of my old brand oil in a jar and
added an equal part of new brand. So far, nothing adverse seems to be
happening. The oils seem to have mixed well and there is no jelling,
etc. (Currently placed in the freezer) What is the potential harm? I have been using the Pennzoil TC, and now going to switch to Citgo Faso FC/EGD/TC specs which is more available and from everything that I have been able to read, better than a TC oil.
larry
shilocom(at)mcmsys.com Guest
Posted: Tue Oct 17, 2006 7:49 am Post subject: Mixing brands |
Before I had oil injection, I mixed Pennzoil and AMSOIL as a premix in the fuel tank,,,that is I had some Pennzoil premixed gasoline in the tank (probably about 3 gal) and I mixed about 6 gallon of Amsoil premix with it and "cloged" my fuel filter with a gel with in an hours flight. Luckily my series plumbed auxiliary electric fuel pump was able to force enough fuel thru it to get me home....twice. The first time I landed at the nearest airport, removed the fuel hose from the input of the engine pump and turned on the electric pump and got a "real good flow" of fuel. So I hooked everything back up and headed for home,,,about an hour away and the same thing happened about 45 minutes later. Again the electric pump got me home. Before Jay D says it....His fuel pressure switch would have probably told me what was going one for sure or even encouraged me from NOT taking off at all. Go Jay....smile. Bob U.
