drfred(at)cox-internet.co Guest
Posted: Thu Oct 05, 2006 5:42 am Post subject: Fuel tanks |
I'm not thinking of putting a fuel injected engine on my RV, but
installing a return fitting seems like a good idea. What fitting would
be the best? What is typically used?
Also, the book places the chapter on the bottom skin after the
completion of the fuel tanks and before installation of the aileron/flap
acutation systems. Are most builders putting off attaching the bottom
skin until after the flaps/ailerons/acuation system is complete?
Thanks.
Fred
Proseal is fun........it's the MEK to clean it up that's the problem.
Deems Davis
Posted: Thu Oct 05, 2006 6:12 am Post subject: Fuel tanks |
I haven't installed them yet, (wings are stored (at) airport)but here's
what I got to plumb a return line into one of my tanks.
http://www.safeair1.com/index.htm
Deems Davis # 406
Panel/Finishing
http://deemsrv10.com/
Fred Williams, M.D. wrote:
<drfred(at)cox-internet.com>
would be the best? What is typically used?
aileron/flap acutation systems. Are most builders putting off
attaching the bottom skin until after the flaps/ailerons/acuation
system is complete?
Thanks.
Fred
Rick S.
Posted: Thu Oct 05, 2006 6:37 am Post subject: Fuel tanks |
It is a bear to rivet the bottom skins on with the aileron hardware installed, if not impossible in some spots. I did my skins with the tanks on but would have been easier with them off, just make sure no warps, the tanks help keep everything straight while the bottoms go on. An an 6 fitting bulkhead fitting should be adequate to allow you to attach a return line to, a 4 might work but you will need to know the return flow volumn and rate to make sure.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
rene(at)felker.com Guest
Posted: Thu Oct 05, 2006 6:53 am Post subject: Fuel tanks |
I skipped around and did the fuel tanks, leading edge (outboard), flaps, and
ailerons before I started the main part of the wing. I did not put the
bottom skin on until the very end........riveting the bottom skin was a pain
in the ..... arm, back, etc.
Rene' Felker
rvbuilder(at)sausen.net Guest
Posted: Thu Oct 05, 2006 8:09 am Post subject: Fuel tanks |
If you haven't put the tanks together yet you can install the return
line in the top of the tank just like the feed line. It is also best
that your return line extends at least 1 or 2 bays so you give the hot
fuel a chance to mix with cooler fuel and eliminate any air bubbles
before it is picked back up. Best case is to send it to the far bay but
2 should be fine.
Looking at my AFP FM-300 manual it is looking for anything in AN2-AN4
range for the purge line. I think the Egg engine is looking for AN5
though so if you can't decide I would just go with that. Then just get
a couple AN837 and associated fittings and you should be good to go.
Michael Sausen
-10 #352 Fuselage
dmaib@me.com
Posted: Thu Oct 05, 2006 11:55 am Post subject: Fuel tanks |
Deems,
Did you buy the extended range bungs to install for a return line? I have been thinking I might use one of those for a return line.
David Maib
40559
tailcone
On Thursday, October 05, 2006, at 07:29AM, Deems Davis <deemsdavis(at)cox.net> wrote:
Deems Davis # 406
Panel/Finishing
> system is complete?
> Thanks.
> Fred
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
wcurtis(at)core.com Guest
Posted: Thu Oct 05, 2006 12:56 pm Post subject: Fuel tanks |
No need to buy them from Safeair for $23.95 a pair when Van's sell the VA-112 pre drilled "bung" (same 1/8 NPT "bung" used on fuel tank drain) for about $7.80 each. See Page 18-2 of the plans, or find it on "The List" Or you can do what I did here, just in case I want to add an extended range tank: http://wcurtis.nerv10.com/07Wings/wings58a.html >I haven't installed them yet, (wings are stored (at) airport)but here's >what I got to plumb a return line into one of my tanks. > >http://www.safeair1.com/index.htm > >Deems Davis # 406 >Panel/Finishing >http://deemsrv10.com/ > William Curtis http://wcurtis.nerv10.com/ [quote][b]
Posted: Thu Oct 05, 2006 1:11 pm Post subject: Fuel tanks |
Follow the plans Fred. The bottom skins go on LAST. Yes, you will get lots of scrapes and scars on your arms--of all the riveting I've done on the RV-10, this was by far the hardest. Also, an extra person does not help with these, they just get in the way. You can remove the torque tube temporarily AFTER you have constructed it and made adjustments to rivet the bottom skins. > > >I'm not thinking of putting a fuel injected engine on my RV, but >installing a return fitting seems like a good idea. What >fitting would >be the best? What is typically used? > >Also, the book places the chapter on the bottom skin after the >completion of the fuel tanks and before installation of the aileron/flap >acutation systems. Are most builders putting off attaching the bottom >skin until after the flaps/ailerons/acuation system is complete? > >Thanks. > >Fred > William Curtis http://wcurtis.nerv10.com/ [quote][b]
dav1111(at)cox.net Guest
Posted: Thu Oct 05, 2006 1:49 pm Post subject: Fuel tanks |
I disagree. A person to either help you buck or rivet will make the bottom skins a lot easier. If you have the wing on an upright rack even a third person to stand behind the wing to steady it while the bottom skin is being riveted is also helpful. There will be a bunch of rivets that you will probably want to set with pop rivets as well simply because even with another person bucking they won't be able to reach far enough through the access panel holes to buck every rivet.
Russ Daves
N710RV Flying
See you at LOE 10/13/06
Posted: Thu Oct 05, 2006 2:15 pm Post subject: Fuel tanks |
Michael/Deems/Rene
thanks for the iniput. Ive got a couple ways to go. I'll probably
manufacture all the rods and connections , make sure they work, then
pull them out and then put the skins on. I'll look for those fittings
later tonight. It just looked easier to make sure nothing was rubbing
and make sure the acuator arms all worked like they were supposed to
before closing up the wing.
Fred.
Posted: Thu Oct 05, 2006 2:33 pm Post subject: Fuel tanks |
I agree with Russ………or do I say I agree to disagree. Just finished my bottom skins about a month and a half ago. Two people is a must. A third can help some, but they will get board. I did some riveting on a vertical stand, but changed to table. The table was much easier. First wing I used two pop rivets the second wing I used 0. Follow the order very closely and you can get them all even with short arms like me. Just make sure you start towards the middle of the large sheet and work the center section on both the rear and main spar or you will have to use some pop rivets on the main spar. Good luck.
Rene' Felker
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Russell Daves
Sent: Thursday, October 05, 2006 3:45 PM
Subject: Re: Re: Fuel tanks
Russ Daves
N710RV Flying
Posted: Thu Oct 05, 2006 7:15 pm Post subject: Fuel tanks |
I agree with Russ, but then I riveted and bucked every one of them myself on my bottom skins, no pop rivets. The reason I agree with Russ is #1 the experience I now have :], and #2 the amount of bondo I’ll have to use during paint prep to cover the dings and dents that I put in the skins.
Rob Wright
#392
Sent: Thursday, October 05, 2006 4:45 PM
Russ Daves
N710RV Flying
bob.kaufmann(at)cox.net Guest
Posted: Thu Oct 05, 2006 8:33 pm Post subject: Fuel tanks |
I followed the directions in the plans with the bottom rivets, my wife on the rivet gun and me bucking and we were able to do all the rivets without using pop rivets. I think it only cost a pint of blood on the left arm and 2/3 of a pint on the right. Got better with time. It was a pain in the backsides and the torque tubes absolutely have to be out of the wing, and your arm has to be a long one. The finished product looks better than the rudder.
Bob K
Except for the blood stains. :<))
Waiting to see the TEXAS TECH Special.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Wright
Sent: Thursday, October 05, 2006 7:13 PM
Subject: RE: Re: Fuel tanks
Rob Wright
#392
Russ Daves
N710RV Flying
Posted: Fri Oct 06, 2006 2:41 am Post subject: Fuel tanks |
Thanks to Rene and Rob for agreeing with me. One thing I forgot to tell you about the pop rivets, on my QB wings two of the ribs were installed backwards which caused much of the problems in having to go with about a dozen pop rivets on each bottom skin. The two ribs were installed with facing into the center instead of facing out from the center. Try bucking all of those even with two people!!
For all you purists, yes I know I could have drilled out both ribs and reinstalled them in their proper place but since it was not a structural issue I just used metal glaze to fill the pop rivet holes on the bottom skin before painting.
Being one of the first set of deliveries of the QB wings and fuselage from across the water resulted in a number of things not being perfect because of the learning curve both at Van's and in the Philippines.
Do I regret it? Not on your life.
As so many before me have said, don't worry over the little stuff, just build it, after painting only you will know every little screw up you made.
Russ Daves
Deems Davis
Posted: Sun Oct 08, 2006 2:45 pm Post subject: Fuel tanks |
Yup, that's my plan.
Deems Davis # 406
Panel/Finishing
David Maib wrote:
Deems,
David Maib
40559
tailcone
>Deems Davis # 406
>Panel/Finishing
>>system is complete?
>>Thanks.
>>Fred
