gommone7(at)bellsouth.net Guest
Posted: Thu Oct 05, 2006 4:38 pm Post subject: : Hugo Rv10#40456 |
Hi,reading about the floor panels,10 minutes ago just finished the final riveting,I also have a QB ,I remove the gear bracket,in order to remove the pans,are only few rivets,I epoxy primer everithing and install sound proffing underneat the pans,not in the bottom,now this is what I found,
even if was riveted and primer the line of rivets along the tunnel at the fire wall and aft,where not match #30,I found this after many rivets set at the floor,some body in the phillipines wake up for my thinking,
any way before install the copilot side I correct this ,and come smooth,refer to Van's (scott risan) will refer to the Phillys crew ,may be I help some one in the QB # 650 or so.
By the way if somebody remove the landing gear bracket I suggest order a new set of bolts,they are install with stress,I will not reinstall the same ones,probably 15 0 20 doll worth in bolts.
Hugo
