Nick(at)Scholtes1.com Guest
Posted: Wed Oct 04, 2006 11:21 am Post subject: Rudder Authority |
Ted and Guy,
Thank you both, as well as everyone else, for EXCELLENT responses!
Ted wrote:
Kitfox rudder control is pretty much required all the time on the ground or in the air. In smooth stable air no prob -- hands and feet off when trimmed. In thermals or wind you're making rudder adjustments as well as pitch and roll most of the time. A Kitfox is flown like a sports car rather than a sedan. It takes more attention but that's why they're fun. What you describe is typical of folks who have not spent a lot of time in light short-coupled fabric taildraggers.
Ted, I've got alot of time in the Citabria and the Decathlon and even a C-150-TD, but zero time in a KitFox (actually, I've now got 0.9 hours in one!). Would you consider these "light, short-coupled fabric taildraggers"? I guess I was expecting the KitFox to perform alot like these, but it didn't, and maybe my problem is just a mismatch between my expectations and reality. What I'm trying to figure out is whether I should adjust my expectations, or whether that particular airplane is an anomaly.
Guy wrote:
Mine tracks very nicely as long as your feet are on the pedals, even in turbulence. It just doesn't center very well. You can be as much as one ball off and feel nothing in the pedals. (My butt's not attuned to it yet, either.) Other IV's with the thick rudder "option" do center.
I understand your description of "centering" and "tracking". There is a C-150 that I fly alot that doesn't "center" very well, as you describe you can be sitting there and your "butt-ometer" is saying everything is fine, but you look at the ball and you're one ball off-center. But, that airplane is easy to handle, and it "tracks" well, meaning that it kinda' stays where you put it, just a touch of pedal after you look at the ball and all is well. The KitFox that I flew neither "centered" well, nor "tracked" well. It was just all over the place, all of the time. As a matter of fact, on one approach that I did, the owner said, "see how well it comes down when you're slipping it to a landing?" He was right, it was doing a great slip. Problem was, I was trying to fly it straight!
I just need to fly more KitFoxes to do some comparisons.
So, I'll change my tactic. Instead of asking questions, I just need some stick and rudder time, so I'll ask this:
Who out there has a Model IV-1200 that I can take for a ride? I'll pay handsomely for the opportunity. The closer to Chicago the better! Any takers?
Thanks everybody!
Nick
FLIER(at)sbcglobal.net Guest
Posted: Wed Oct 04, 2006 1:29 pm Post subject: Rudder Authority |
The 'Fox is lighter and more spirited than any of the
below. I've flown them all and the Kitfox is more
responsive and as a result can require more attention.
Ted
--- Original Message ---
To: "kitfox-list(at)matronics.com" <kitfox-
list(at)matronics.com>
Subject: Rudder Authority
| Quote: | Ted and Guy,
| Quote: | or in the air. In smooth stable air no prob -- hands
and feet off when
| Quote: | trimmed. In thermals or wind you're making rudder
| Quote: | pitch and roll most of the time. A Kitfox is flown
like a sports car
| Quote: | rather than a sedan. It takes more attention but
| Quote: | What you describe is typical of folks who have not
spent a lot of time
| Quote: | in light short-coupled fabric taildraggers.
| Quote: | C-150-TD, but zero time in a KitFox (actually, I've
| Quote: | one!). Would you consider these "light, short-
coupled fabric
| Quote: | taildraggers"? I guess I was expecting the KitFox
| Quote: | these, but it didn't, and maybe my problem is just a
mismatch between my
| Quote: | expectations and reality. What I'm trying to figure
out is whether I
| Quote: | should adjust my expectations, or whether that
| Quote: | anomaly.
the pedals, even in
| Quote: | turbulence. It just doesn't center very well. You
| Quote: | ball off and feel nothing in the pedals. (My butt's
not attuned to it
| Quote: | yet, either.) Other IV's with the thick
| Quote: | C-150 that I fly alot that doesn't "center" very
| Quote: | you can be sitting there and your "butt-ometer" is
| Quote: | fine, but you look at the ball and you're one ball
off-center. But,
| Quote: | that airplane is easy to handle, and it "tracks"
| Quote: | kinda' stays where you put it, just a touch of pedal
after you look at
| Quote: | the ball and all is well. The KitFox that I flew
neither "centered"
| Quote: | well, nor "tracked" well. It was just all over the
place, all of the
| Quote: | time. As a matter of fact, on one approach that I
| Quote: | "see how well it comes down when you're slipping it
to a landing?" He
| Quote: | was right, it was doing a great slip. Problem was,
I was trying to fly
| Quote: | it straight!
comparisons.
| Quote: | some stick and rudder time, so I'll ask this:
| Quote: | handsomely for the opportunity. The closer to
| Quote: | takers?
Thanks everybody!
Nick
