Malcolmbru(at)aol.com Guest
Posted: Wed Oct 04, 2006 6:16 pm Post subject: Rudder Authorityand adverse yaw |
My first flight in my kf2 was solo but I had 2 hr. taxi time. I lasted 3 min and landed only a little bounce but it seemed to be all over the place in the air. the 2ed time I flew it the right door opened and I was all over the place till I landed. It got really windy in there a couple of times. now I have 15 hr. and 50 landings. and I feal much moor confident now . I find with full flaps I have a little less rudder authority. when I did the weight and balance I found I put my CG a little forword of the middle of its center of CG range by adding the E box and larger battery. wouldent it be cool if I put myCG closer to my senter of side area by adding the 582 w/ e box and larger battery, still learning michigan kit foxer malcolm
