tonyk(at)kaon.co.nz Guest
Posted: Mon Oct 02, 2006 11:33 am Post subject: banjo fitting |
"As I understand it (I haven't removed a banjo from the regulator), the
copper washers go between the head of the banjo bolt & banjo and between
the banjo & regulator. They do not go on the AN portion of the fitting.
Supposedly, these copper washers are one use only. You can not re-use
them. So if you remove the fitting for any reason, new copper washers
are required."
That's correct. The copper washers have a small indent in them,
presumably to act like a lock washer, and they are specified as one time
use only. I suspect that Europa 2004 have them in stock as they are part
of the fuel pressure sensor kit they are now selling for the 912/914
engines.
Incidentally, if anyone want to interface the UMA pressure sensors used
with the kit to an Engine management system I have a table showing
voltage output vs indicated pressure.
Tony
