dan(at)rdan.com Guest
Posted: Mon Jan 23, 2006 7:11 pm Post subject: first real dimples |
Ok I am just now setting my first real dimples in the HS spars and ribs,
pneumatic squeezer, do I want to see the slight ring imprint also ,? or am I just a little deep ?
How about when I get to the skin ??
Thanks all,.,
Dan Hatch
-8 QB
N728RV Reserved
and gettin on a roll !
dan.beadle(at)inclinesoft Guest
Posted: Mon Jan 23, 2006 7:29 pm Post subject: first real dimples |
I overdid the dimpling on my first try. I used a lot of pressure. TOO
MUCH. What you want is to have the dies just touch the surface. In my
case, the excessive pressure caused the holes to expand, making a cleco not
hold well.
Another test is to insert an AN426 rivet. The top of the rivet should be
flush with the skin. And the mating part, the spar or rib, should be
dimpled enough to accept the skin without visible separation.
Hope this helps.
Dan
truflite(at)yahoo.com Guest
Posted: Mon Jan 23, 2006 9:12 pm Post subject: first real dimples |
The slight imprint is good and is not a problem. It
means the die has fully depressed the dimple. If,
outside that ring,you see bulging, it is too much
pressure.
Dave
--- Dan <dan(at)rdan.com> wrote:
Thanks all,.,
Dan Hatch
-8 QB
N728RV Reserved
browse
Subscriptions page,
FAQ,
Admin.
jabowenjr(at)hotmail.com Guest
Posted: Fri Jan 27, 2006 3:18 am Post subject: first real dimples |
Yes Dan, I used a pneumatic squeezer extensivly and had the same effect.
Just set a rivit in the dimple and it will show you if the dept is correct.
Use some scrap alum. sheet for practice when you go to a different thickness
to set the dimple depth. I think they say, your not building a swiss watch
here. Have fun. It will look great.
Jim Bowen
RV-8 QB
| Quote: | From: Dan <dan(at)rdan.com>
Reply-To: rv-list(at)matronics.com
Subject: first real dimples
Date: Mon, 23 Jan 2006 19:10:33 -0800 (PST)
Thanks all,.,
Dan Hatch
-8 QB
N728RV Reserved
