				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| richard.goode(at)russiana Guest
				|  Posted: Mon Jan 23, 2006 10:08 am    Post subject: 52 overhaul schedules |   |
				| 52 overhaul schedules plus IRAN
 I know nothing about CJ6 maintenance,but  suspect that, in military use, it is pretty similar to Yak-52.
 For the Yak-52 in Soviet use, every aircraft  was returned to a major overhaul facility at 500 hours, with an  extension to 600 hours where appropriate, and totally overhauled.
 This means it was stripped down to the last  night and bolt and then rebuilt as a new aircraft.  This is not IRAN, but a  total rebuild!
 Obviously the State was paying and so no  cost consideration; the aircraft were being flown very hard, but the fact  remains that is the level of maintenance that was expected.
 Obviously more gentle western use should be  reflected in less onerous maintenance, but that is what the manufacturer  intended.  In the UK, we  have persuaded Yakovlev and the UK CAA that  the 600 hour overhaul can be replaced with a detailed inspection, but even this  involves wings and tail removal; engine out; x-rays / magnaflax etc. every 600  hours
 If there is a problem through lack of  maintenance, I suspect that an excuse that the maintenance was not locally  compulsory would not be accepted!
 Richard Goode Aerobatics
 Rhodds  Farm
 Lyonshall
 Herefordshire
 HR5 3LW
 United Kingdom
 Tel:  +44 (0) 1544 340120
 Fax: +44 (0) 1544 340129
 www.russianaeros.com
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| brian
				|  Posted: Mon Jan 23, 2006 1:28 pm    Post subject: 52 overhaul schedules |   |
				| Richard Goode wrote:
  	  | Quote: |  	  | 52 overhaul schedules plus IRAN
 appropriate, and *totally overhauled. *
 That is similar to the Chinese schedule.
  	  | Quote: |  	  | This means it was stripped down to the last night and bolt and then
 That is different. The Chinese IRAN, not overhaul. But then they throw
 the airplane away at 3000 hours.
  	  | Quote: |  	  | Obviously the State was paying and so no cost consideration; the aircraft were being flown very hard, but the fact remains that is the
 That does seem a bit stiff.
  	  | Quote: |  	  | If there is a problem through lack of maintenance, I suspect that an excuse that the maintenance was not locally compulsory would not be
 accepted!
 I don't think it would be here either. The FAA would probably slap you
 with the "careless and reckless" clause because you ignored accepted
 maintenance procedures and it caused an incident or accident.
 BTW, did Sean Carroll ever pay you the money he owes you? I still
 haven't gotten anything out of him.
 Brian Lloyd                         2243 Cattle Dr.
 brian-yak at lloyd dot com          Folsom, CA 95630
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 - Antoine de Saint-Exupery
 Brian Lloyd
		| Back to top |  |
		| BitterlichMG(at)cherrypoi Guest
				|  Posted: Mon Jan 23, 2006 3:36 pm    Post subject: 52 overhaul schedules |   |
				| Richard,
 I was  aware of the 500 hour rebuild in Russia and what was accomplished during them,  from talking at length with Vladimir Yastremski and Sergei Boriak.
 What I  was not aware of was your mention of xrays and magnafluxing.
 Do you  have details on those inspections that the Russians were doing (regarding Non  Destructive Inspections [NDI]), or are these inspections something that you have  come up with locally?
 Thanks  for the information.
 Mark  Bitterlich
 N50YK
 [quote]   --
		| Back to top |  |
		| BasiliereR(at)ci.boulder. Guest
				|  Posted: Mon Jan 23, 2006 4:18 pm    Post subject: 52 overhaul schedules |   |
				| It's in the SU-29 manuals.  Magnaflux and some kinda ultra sound test for the composite wings - hasn't applied until this year for me  - the rear wing spar attachment thing.  But, "it's in there"
 If you want the Sukhoi -word for word - contact me off list I'll copy it for you.
 Rick b
 Richard,
 Mark Bitterlich
 N50YK
 [quote] --
		| Back to top |  |
				|  Posted: Mon Jan 23, 2006 4:29 pm    Post subject: 52 overhaul schedules |   |
				| I appreciate the offer Rick, but it would  seem to me that the requirements would differ between the YAK-50 and the SU-29  by quite a margin given their massive difference in design.  Still....  metal is metal..... so yes, I would be interested in hearing what exactly they  are looking for cracks in.
 I don't keep up much with Sukes... but does  this rear spar deal also apply to the 26's and 31's and if so, how often?   I have friends here with both aircraft and I do not see them making any special  inspections... and I'd know.  Perhaps they are overlooking something  important?  If you know of a mandatory rear spar inspection using  magnaflux on the SU-26's or 31's PLEASE let me know  ASAP!
 Mark Bitterlich
 [quote]   -----Original    Message-----
 From: owner-yak-list-server(at)matronics.com    [mailto:owner-yak-list-server(at)matronics.com]On Behalf Of Richard    Basiliere
 Sent: Monday, January 23, 2006 7:17 PM
 To:    yak-list(at)matronics.com
 Subject: RE: 52 overhaul    schedules
 Rick b
 Richard,
 Mark    Bitterlich
 N50YK
 [quote]     --
		| Back to top |  |
				|  Posted: Mon Jan 23, 2006 4:49 pm    Post subject: 52 overhaul schedules |   |
				| I understand.  I was just putting in my 1 cents worth that the Russians do think about that techno stuff.
 The cracking problem was identified in Nik Timofeev's SU-29 and applies only to the -29.  He found his port side rear spar attach fitting broken and the starboard cracked.  So, I think this is a one time thing.  The Russians, from what I've gathered from their communications on it think its an anomaly and are treating it as such.  The Friendly Aviation Agency is pushing as hard as it legitimately can to issue this as an AD.  My notification was on "FAA AD letterhead" so to speak - you know -the same format.  So...according the FAA it is mandatory for we SU-29 drivers only.
 I started my Annual Conditional Inspection a few days ago and mine are fine - both sides.  I think Nik's is a unique case but it doesn't take much at all to check while you have the sides off the airplane off for inspection anyway.
 Yak-50 huh?  A great relative to have.  I never flew one but Azat (my Ukraine bud - National Champion) loves the darned things he flew/flys them for the "Yakovlevs" UK Akro formation group when he's not flying Capt. on B-737 for Ukraine International Airlines (yea Azat).
 Respectfully, rick b
 Mark Bitterlich
 [quote] --
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
