Coolant temp. sensor
sidsel.svein(at)oslo.onli
PostPosted: Thu Sep 28, 2006 9:57 am    Post subject: Coolant temp. sensor Reply with quote
I have just received a reply from GRT on the coolant temp sensor connection to their EIS 4000 - they confirm that Aux. 4 can actually be used by the arrangement shown attached with the VDO type temp sensor that e.g. Skydrive sells with the T-piece to be inserted in the coolant tubing - or one of the sensors installed by the factory in two of the cylinder heads.
Best regards,
Svein
 Filesize:  96.59 KB
 Viewed:  199 Time(s)
