GRT EFIS & Pitot Static Check
coop85(at)bellsouth.net
PostPosted: Tue Sep 26, 2006 2:06 pm    Post subject: GRT EFIS & Pitot Static Check Reply with quote
I'm ready to start traveling around this great country in our RV-10 so I
started looking into the XPDR Mode C certification and Pitot Static checks.
I know the XPRD encoder check is required to operate Mode C. I spoke to the
local avionics guy and he said they remove the altimeter and encoder from
the airplane and hook it to the test equipment. Not possible with the GRT
EFIS so we are looking into how to actually do this.
The questions are:
- is the pitot static check (run it up to 20K and see how it responds)
required for an experimental to fly IFR?
- How have folks performed the pitot static check (if required) and the
XPDR encoder check with a GRT EFIS?
Marcus
indigoonlatigo(at)msn.com
PostPosted: Tue Sep 26, 2006 3:45 pm    Post subject: GRT EFIS & Pitot Static Check Reply with quote
When I have had my bi-annual transponder certification on my sailplane, all
they did was to hook a pressure device to the single airline going into the
encoder and then run through all the different frequencies on the
transponder while changing the pressure into the encoder to verify it is
functioning correctly.
Mode C has nothing to do with EXPERIMENTAL catagory, but is required for
Class B airspace, so to with Class A(IFR). I am unfamiliar with the GRT
EFIS, does this have its own encoder built in or is it too connected to a
seperate encoder? If seperate, would it not be the same as my above test.
No one has ever checked the entire static system for leaks while checking
the transponder certificaion.
I'm not clear on how a static leak or error, would be discoverred if both
the encoder and the altimeter are hooked to the same static system? Approach
control radar does not determine ones altitude, that's why we have mode C.
The encoder is set to 29.92 and then we set the manual altimeter to current
barometric pressure, but if the encoder is hooked to the same static line
both will have errors when we give our initial reporting altitude. even when
they correct for the difference in barometric pressure, current vs. 29.92
I need a little help on this.
JOhn G.
Reply-To: rv10-list(at)matronics.com
Subject: GRT EFIS & Pitot Static Check
Date: Tue, 26 Sep 2006 18:05:05 -0400
the
The questions are:
Marcus
PostPosted: Tue Sep 26, 2006 4:43 pm    Post subject: GRT EFIS & Pitot Static Check Reply with quote
John,
The GRT encoder is built into the system and the same computer drives both
the encoder and altimeter display so there's not going to be any difference.
In that regard I guess I just have to shell out $75 for the Mode C sign-off
even though it's a waste of time. As for the leak, I suspect they use a
calibrated vacuum to raise the simulated altitude to make sure the altimeter
reads the same. As for necessity, I doubt a leak would be that catastrophic
as the pressure inside and out of the airplane are similar (as indicated by
the alternate air source on most airplanes being in the cabin), although not
exactly the same. Definitely an issue with pressurized airplanes, but I
don't have one.
What it really comes down to is I know I need the transponder (really
encoder) certification to turn on the Mode C. Right now I just tell center
every flight that I'm negative Mode C, but I'd sure like to turn it on.
What I'm wondering, is if a pitot-static check is required for IFR flight?
Marcus
40286
jesse(at)itecusa.org
PostPosted: Tue Sep 26, 2006 4:58 pm    Post subject: GRT EFIS & Pitot Static Check Reply with quote
Our local avionics guy did the transponder check and some kind of
pitot/static check in the plane, then wired up a harness on his bench to
test the altimeter, encoder and the Dynon EFIS. Is it not possible to do
something similar with the GRT? He said that he needed to test everything
in the plane that was giving altitude information on his bench.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
dlm46007(at)cox.net
The transponder check can be accomplished in the aircraft if it complies
with the required frequency stability. If it passes frequency then proceeds
to Mode C in the aircraft. The whole system is checked for leaks. Usually
the static system is sealed and a manual vacuum pump in a tester is used to
pump the system to an altitude a couple of thousand feet higher. The tester
then waits to determine altitude loss over time ; i.e. how fast the system
leaks down to ground level. If that passes, then the tester steps the
equipment up to altitude in increments and checks for leaks at each
interval. In most cases, leakage must be almost zero; however as altitude
increases some minor leakage is allowed. During the incremental test the
encoder is checked to see that the output to the transponder corresponds
closely to the visual altitude on the test equipment and on the altimeter in
the aircraft.
My recommendation is that as you are building you should have an avionics
guy visit you fuselage while its open to check for leaks, Tightening
fittings and use of Teflon tape can eliminate most leaks before the final
test. Its a whole lot easier to check when the various connections can be
accessed. Trouble shooting requires isolation of various parts of the system
and can be a bear if you have to open up a lot of access panels to get to
them.
As for the GRT, I suggest that the tester tap into the static system and
check for leaks, and then look for the correspondence on the GRT altitude
readout. The test equipment will show transponder altitude output. BTW,
encoders can have errors and my ACK has two pots on the top to adjust the
output higher and lower.
Tim(at)MyRV10.com
PostPosted: Tue Sep 26, 2006 5:05 pm    Post subject: GRT EFIS & Pitot Static Check Reply with quote
I have a separate ACK A30.8 encoder that feeds my GTX330 and
GNS-480, but I previously did use the Air data of the EIS 6000
for my system too. Next test I'll be having to use the
pinpoint since my air data is now coming from that. During the
IFR pitot static test, they checked the pitot system for
speed and for leaks, and they checked the static system for
accuracy, but never did they have to remove it from the plane.
I do believe they hooked directly to the ACK at one point, and
since that is a TSO'd device, I consider that the one that
ATC would care about. But, the one that I myself really cared
about was the EIS 6000 before (and the pinpoint now), since
that's the one that will keep me away from the ground. I have
my ACK set for 10' resolution. The cool thing about the EIS
though was that the air data came out so that my accuracy
was within something like 7' all the way to 20K, since you could
put in some calibration factors. What's really cool too is
the pinpoint shows the *exact* same altitude as the EIS 6000,
and the *exact* same airspeed as well...and during the calibration
those were right on as well. The pinpoint has been tested
at the factory to something like 8' accuracy from zero to 40K'
or something like that.
Then, in testing the transponder, they did like John's reply
said....they cycled through the various codes, checking to
see what altitude it reported and what code it showed. I also
paid just that tad bit more and got the Mode S addition to
the IFR pitot static test done. That way they can verify if
your Mode S TIS information is displaying and working properly.
But, at no point did any of the equipment get removed from
the airplane to accomplish this. The cart was rolled next to the
rear step, and it was done inside a hanger.
If you can't accomplish a similar result with your local
place, maybe try calling around a bit. You should
be able to do what you need. Rumor has it though that
some people will not test the experimental, non-TSO'd
stuff. The guy that did mine didn't have a problem with
it, but he was very happy that I had the ACK encoder there,
because it gave him that comfort factor. To him, the
zeroing in on the EIS6000 was just a side benefit. He
was very impressed with the accuracy of the system though.
The questions are:
Marcus
dlm46007(at)cox.net
leakage for IFR is not acceptable. Check FAR 43 appendix E and F.
deutscht(at)rhwhotels.com
Can we do our own certifications if we have received a repairman's
certificate issued by the faa on our airplane?
Tim(at)MyRV10.com
PostPosted: Tue Sep 26, 2006 5:21 pm    Post subject: GRT EFIS & Pitot Static Check Reply with quote
Yes, the pitot static check is required for IFR flight, to the
best of my knowledge. Why anyone would fly IFR without one would
be beyond my understanding.
John,
don't have one.
Marcus
40286
dlm46007(at)cox.net
PostPosted: Tue Sep 26, 2006 6:43 pm    Post subject: GRT EFIS & Pitot Static Check Reply with quote
No. check FAR 43 appendix E and F. The calibrated equipment is costly and
you need the FAA's blessing. Neither IA or A&P is approved for same unless
separately blessed.
