Gilles.Thesee(at)ac-greno Guest
Posted: Mon Nov 27, 2006 3:59 pm Post subject: Checking bolt torque |
Hi all,
There has been considerable discussion on the Jabiru Yahoo list as to
how to check torque on critical flywheel bolts.
The owner/mechanic is suppose to regularly check those bolts tension,
but they are bonded with Loctite 620.
How would you experts proceed ?
- Just apply torque wrench and check for movement ? (But remember there
is Loctite)
- Unscrew, extract, clean Loctite, reapply Loctite, reinsert and torque
to specified value ?
- Put red paint on bolt heads and flywheel and just check if nothing
moved ? (but what if the preload relaxed, the bolts stretched, the joint
fretted ?)
- Etc..
I posted some info on bolt torquing and the Jabiru SB which started it all :
http://contrails.free.fr/engine_jab_bolts.php
Any qualified input appreciated
Gilles Thesee
Grenoble, France
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
Bob H
Posted: Sat Dec 02, 2006 9:46 am Post subject: Re: Checking bolt torque |
I would use your second procedure of removing bolts, clean threads of any residue and reinstall to correct torque, using suggested Locktite.
It is more common practice in US to install bolts dry as torquing dry provides a more uniform/repeating loading and bolts used a cadmium plating to provide lubricity and corrosion protection. However, many fastener suppliers have been forced away from cad plating because of toxicity issues in the plating process.
When you add a Locktite to threads, friction is reduced and bolt receives higher loading for a given applied torque. Jabiru must have accounted for this higher loading when making that recommendation.
Taking a tensile bolt to 90% of Yield is a risky business in that the variations in thread geometry/hole tolerance and friction and torque wrench errors can easily cause overtorquing. We usually select a torque value around 60% of Yield to provide sufficient margin for errors. If a situation requires higher clamping forces, a larger dia fastener is chosen. With hardware already in service, installing shear pins is a way to takeout that loading and reduce bolt torque to a more reasonable level.
It would be interesting for Jabiru to indicate what the mode of failure has been on those bolts; a shear overload or tensile fatigue. And the bolt pic showed failure in threads which can indicate that threads are overloaded and geometric stress concentrations from thead form contribute to failure. You don't want threads in bearing and the bolt grip length is sized to carry shear loads on smooth shank, never in threaded portion.
Bob H
