Tim(at)MyRV10.com Guest
Posted: Sun Sep 24, 2006 4:12 pm Post subject: Static port airspeed error update |
As I've mentioned before, my previous speeds listed when
I gave performance stats were inaccurate. For over 100
hours I hadn't ever officially flown the plane against
the 4-way spreadsheet to see how accurate the IAS and
TAS speeds were. Lately, I've been fighting with the airspeed
error doing many test flights with various things.
My original Cleaveland static ports were flush. The older
ones were made that way, and they needed to be mounted on
bare, unprimed skins, and they needed to be painted with
the airframe, to ensure they had a .010" "stickout" from the
fuselage. The error on those ports was -6.5 to -7.5kts, but
I had never been informed that I should have painted them,
so this will have an effect too. I wanted the airspeed to
be as accurate as possible because on the Chelton system
with it's wind computer and everything else, I wanted it
to accurately depict the winds that I was seeing at altitude.
My first test was to put a penny-sized disc of .050"
over them with a hole in it, and the error went down to -4kts.
Next, I put a bridge (like what John sent to the list in the
photo) in front of them and the error was -4 to -4.5 kts.
I wanted to do anything I could to prevent installing different
ports, but after getting a set of the new style rounded head
ports from Mike (Cleaveland Aircraft Tools), I decided this
weekend I was desperate and drilled out my old ones and put
in the new rounded static ports. If there is any installation
flaw left, it's that there is still primer on the skin inside
the airplane (and the port isn't painted either...but I'm
not sure if the new ones are supposed to be) Talk about
an un-fun experience, my lovely wife was the lucky one who
went into the tailcone to disconnect the old ports and
buck the rivets on the new ones....and with the AHRS and
Magnetometer shelves in there it wasn't any fun for her.
On my test flight tonight, the airspeed was held very steady,
which gave me statistics on the computer spreadsheet that
rendered 0.0 standard deviation, so it was very accurate and
I knew I got good data. As it turns out, I'm now only -1.5
to -1.8 kts lower than the displayed TAS on the Chelton, and
considering I was taking the measurements with only 1kt
resolution, I think this is now the best that I can get...and
it's finally within the 3kts that I felt would be "good enough"
for me.
Oh, I also had previously checked for static and pitot system
leaks, by the way. The static system was perfectly tight,
but the pitot system had a leak rate of about 1kt every
20 seconds while at 170kts. That kind of rate I would
consider to be not capable of affecting a really dynamic
airspeed indication, but who knows, maybe it makes up
a .1 or .2kt error.
The nice thing is, today my wind calculations are now
also very good looking compared to actual winds on the
speed runs. They were accurate to within a knot or
two of speed, and the direction was within 5-10 degrees
too...and usually on the <5 degrees.
So, I guess with the new ports from Cleaveland, I think
I have this thing licked. Thanks Mike! I'm having
a pretty hard time finding things to be unhappy about
these days.
ron.mcgann(at)baesystems. Guest
Posted: Sun Sep 24, 2006 4:23 pm Post subject: Static port airspeed error update |
Hi Tim,
Any idea what the altitude error may have been with the original ports?
cheers,
Ron (back in Oz)
187 finishing
Posted: Sun Sep 24, 2006 5:38 pm Post subject: Static port airspeed error update |
Oooooh, you gave me a tough question. There's a lot of variables
in that, with temperatures and such, so getting an exact number
is very hard. So, don't trust this figure, but I think I have it
roughly figured out.
First I had to look at 170kts and 160kts and find how much
pressure in inH20 difference there was in 10kts, then just
estimated how many inH20 per Kt there was at that those
speeds, and figure out how many inH2O variation I had.
Then since I couldn't find a good chart on altitude vs. inH20
I had to get a chart that showed altitudes of 6562' and 8202'
and the associated inHg, and then I just linear-ly came up
with approximately how many feet per in/Hg that was.
Then I took that in/H2O in speed and converted it to inHg
and then multiplied it out with the altitude factor.
I came up with a difference of 131.26'. Now I know
that these pressures aren't exactly linear and there are
more factors involved, but this should give a really
rough idea of what 7kts variation would be. 131' of
altitude could be significant, but remember that both
the airspeed and altitude errors would be completely
different during an approach into and airport at 1000'msl
flying 100kts, so it may not be as bad in that situation.
McGANN, Ron wrote:
[quote] Hi Tim,
cheers,
Ron (back in Oz)
187 finishing
DAVELEIKAM(at)wi.rr.com Guest
Posted: Sun Sep 24, 2006 8:33 pm Post subject: Static port airspeed error update |
While you are on the subject of static ports, should I be looking to
purchase a static port system and install it in the tail cone during the
build? And if so, you talked of a system from Cleveland. Better than
Van's? Others?
And another emp. question while I have your attention. Any suggestions on
the position/strobe light for the tail?
Thanks!
Dave Leikam
Muskego, WI
#40496
N89DA
About to start tailcone
Posted: Mon Sep 25, 2006 3:05 am Post subject: Static port airspeed error update |
Hi Dave,
I guess that question is a very tough one (the static port question).
In general, these aftermarket static ports are much nicer looking and
provide a better attachment for the static line. The cleaveland ports
allow me to use the very flexible Tygon tubing, and the barb fittings
seal really well. So the aftermarket ports have some benefits besides
looking nicer. One of the big problems though is, on the RV-10,
I've never once heard anyone else post numbers that they've got
from flying a 3 or 4-way box to find their true airspeed. Some people
have bought the SafeAir ports, which I'd assume are good, and
some have stuck with the Van's pop rivet. But, until we get numbers
from people, how would we know how accurate they are? Also, the
people should take the extra step as I did to have the tester run
on their pitot system when they get their IFR pitot static test
done. Once we get a few people running the numbers we can better
evaluate the ports. Until then, people can make claims one way
or the other, but I wouldn't believe any anecdotal "These work
great" claims without data....I thought my old ones worked
great too.
As for the position and strobe lights for the tail, I got the
Whelen combo strobe/tail light from Van's. It seems to work
fine, so I couldn't ask for much more. You don't need that
though until it's time to attach that lower rudder fairing, or
even until final assembly if you wish.
Van's? Others?
on the position/strobe light for the tail?
Thanks!
Dave Leikam
Muskego, WI
#40496
N89DA
