khorton01(at)rogers.com Guest
Posted: Sun Sep 17, 2006 2:52 am Post subject: [Bulk] Unfortunate Mistake |
On 16 Sep 2006, at 22:46, dmaib(at)mac.com (dmaib(at)mac.com) wrote:
| Quote: | | I had an accident this afternoon when on of my RV-10 Quick Build wings slipped off the cradle. The inboard leading edge was dented and the inboard fuel tank panel was slightly deformed. I am looking for advice on how to gracefully recover from this (completely preventable) mistake. |
I don't think you should try to salvage that tank. If you leave it as is, the stress on the tank inner rib and the wing skin may eventually lead to a fuel tank leak. And, the incorrect profile on the inboard wing leading edge could affect stall characteristics and stall speed. I don't see any way to do a repair short of rebuilding the whole tank.
I think you should order parts and plan to build a new tank. The RV Yeller Pages list several companies that will build RV fuel tanks, if you don't want to do that job yourself:
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
rocketbob(at)gmail.com Guest
Posted: Sun Sep 17, 2006 6:39 am Post subject: [Bulk] Unfortunate Mistake |
I've seen RV's with dents from bird strikes that weren't affected at all in flight by dents far bigger than that one, so I respectfully disagree with Kevin. I would make a form block out of wood and try to work the dent out as best as you can from the inboard side. If that doesn't work I'd remove the rib try to work it out that way, and make a custom rib or cover plate in the rib. If you're careful about how you remove the dent you will never notice it with paint on the airplane.
I have a friend with an RV-8 that had a severe dent in the leading edge right on a rib, just outboard of the fuel tank. Much worse than this one. It was creased right along the rib. He had an old-timer metal man work the dent out, it took him all of 30 minutes to accomplish. I was there and watched him do it, he made a form block out of wood and gently pried it back into shape with a small bottle jack and some blocks of wood inside the wing against the spar (long story short). You cannot tell there was a dent, and there was no body filler used. It was a very creative fix!
Bob Japundza
RV-6 flying, F1 under const.
On 9/17/06, Kevin Horton <khorton01(at)rogers.com (khorton01(at)rogers.com)> wrote:[quote]
Ottawa, Canada
[quote][b] http://www.matronics.com/Navigator?RV-List http://forums.matronics.com http://wiki.matronics.com
Posted: Sun Sep 17, 2006 7:44 am Post subject: [Bulk] Unfortunate Mistake |
Bob - Did the guys with the bird strike dents do a full set of stall characteristics and stall speed tests before fixing the dents?
David - Where are the inspection covers in the RV-10 tanks? In the rear baffle? It might be possible to remove the root rib, but you'll need access inside the tank to scrape the proseal off or you'll never be able to extract the rib. You'll also need access so you can put some proseal along the rib/skin junction after riveting the rib back in place.
I'm not familiar with the RV-10. How is that tank/fuselage attachment fitting attached to the root rib? Can it be riveted to the rib before riveting the rib back in place?
Kevin Horton
On 17 Sep 2006, at 10:38, Bob J. wrote:
| Quote: | I've seen RV's with dents from bird strikes that weren't affected at all in flight by dents far bigger than that one, so I respectfully disagree with Kevin. I would make a form block out of wood and try to work the dent out as best as you can from the inboard side. If that doesn't work I'd remove the rib try to work it out that way, and make a custom rib or cover plate in the rib. If you're careful about how you remove the dent you will never notice it with paint on the airplane.
Bob Japundza
On 9/17/06, Kevin Horton <khorton01(at)rogers.com (khorton01(at)rogers.com)> wrote: | Quote: |
Ottawa, Canada
steve(at)newtech.com Guest
Posted: Sun Sep 17, 2006 8:05 am Post subject: [Bulk] Unfortunate Mistake |
Find you a body man that is at least 60 years old. He will be able to
hammer that out to the point you won't be able to tell were the damage
was. It takes a good feel for what the metal is telling him and a good
eye. The younger bondo slingers just don't have the touch.
Steve Eberhart
60 year old RV-7A builder
Bob Japundza
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Mon Sep 18, 2006 5:57 am Post subject: [Bulk] Unfortunate Mistake |
Thanks to all for the help, suggestions, and advice. It now appears
that this won't be as big a job to repair as I initially feared. I
can't imagine building without these forums for information. BTW, my
wings are now properly secured to the cradle! ^_^
David Maib
RV-10 40559
tailcone (and right wing)
to hammer that out to the point you won't be able to tell were the
damage was. It takes a good feel for what the metal is telling him
and a good eye. The younger bondo slingers just don't have the touch.
Steve Eberhart
Bob Japundza
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
