ron.mcgann(at)baesystems. Guest
Posted: Sun Sep 17, 2006 2:21 pm Post subject: Safety Alert WD-415 weldment |
All,
Here is a repost from Vic Syracuse to the VAF forum. I have not seen the message on this list but think it is essential reading for all of us. Thanks Vic for the heads up!
"I thought I should let everyone know that yesterday during a preflight I noticed that the left trim tab had a little more slop in it than usual. I took off the trim cable access cover plate, and it came completely off, meaning the nut was broken from the wd-415 weldment. I know we have talked in the past about that particular piece not looking quite sturdy enough, and right now that looks to be the case. I have a little over 320 hours on the airplane. I did not notice it on my post flight Sunday, but on my preflight prior to my commute home yesterday.
alk about a miracle, though, and the advantages of the RV community. I live at Mallard's Landing in Georgia, and so does Aaron Sims, another RV-10 builder who is not flying yet. Guess who's parts I got to borrow?
So, I am replacing both mine and Aarons with the parts from Dave at Rivethead-aero.com. Ordered them and 4 new cover plates from Van;s last night. I would recommend to those of you who are flying that you check these regularly.
Now, for my opinion on the actual safety if a failure occurs? I think the trim cables are pretty stiff. I did go ahead and make the 15 minute flight home with no problem. If both of them broke, we might have a different story, but that's only conjecture.
Here's the link for the parts:
<http://www.rivethead-aero.com/rv10_005.htm>
Vic" [quote][b]
n223rv(at)wolflakeairport Guest
Posted: Sun Sep 17, 2006 3:11 pm Post subject: Safety Alert WD-415 weldment |
When you take it apart, see if the nut is stainless and if the plate is ferrous steel (use a magnet). I had mine break before flight and determined that if they are both stainless, you cannot break them. But there are a bunch of ones out there that are mixed metal and if you try to bent it, the nut breaks right off.....
We are building a few RV-s at our airport and we checked everyone's stock. They were mixed. I called Van's and explained my findings, they replaced them for free but I don't know if they did anything behind the scenes to fix the issue.
-M
Tim(at)MyRV10.com Guest
Posted: Sun Sep 17, 2006 3:51 pm Post subject: Safety Alert WD-415 weldment |
I think the new parts would be great, but I've never had them
in hand. For an alternative, see this link.
Either way, I personally wouldn't fly with the original parts
as shipped....stainless or otherwise. Why not just make it more
surely safe?
See:
http://www.myrv10.com/N104CD/finishing/20051228/index.html
But those new parts do look great. Mr. Cleaveland Mike...you
should enquire about being a reseller....would be a more common
order source.
Mike Kraus wrote:
[quote] When you take it apart, see if the nut is stainless and if the plate
-M
zackrv8
Posted: Sun Sep 17, 2006 4:30 pm Post subject: Re: Safety Alert WD-415 weldment |
Guys,
Deems has a few pics of the trim tab weldment on his web site at
http://www.deemsrv10.com/album/CNC%20Parts/index.html
Also, I included a couple of pics of the part already mounted on my trim tab cover.
Zack
30.96 KB |
448 Time(s) |
34.84 KB |
462 Time(s) |
_________________ RV8 #80125
RV10 # 40512 |
armywrights(at)adelphia.n Guest
Posted: Sun Sep 17, 2006 6:15 pm Post subject: Safety Alert WD-415 weldment |
All,
Remember that when Vic completed his plane the parts available were only welded on the one side of the nut. Since then the nuts come welded on both sides. Good judgment always prevails, but with the new welded type there may be no structural reason to use the extruded aftermarket brackets.
Of course, they would definitely add a degree or two of reliability to early failure, even if they don't increase the actual safety of the install. For instance, did Van's perhaps design into the system the ability to overpower the weld if there were a control binding issue? No way to do that with the extruded bracket.
Rob Wright
#392
Wing Tips
mike(at)cleavelandtool.co Guest
Posted: Mon Sep 18, 2006 6:17 am Post subject: Safety Alert WD-415 weldment |
We have talked about this but have not made any progress thus far.
barnettephillip(at)yahoo. Guest
Posted: Mon Sep 18, 2006 11:07 am Post subject: Safety Alert WD-415 weldment |
ordered the rivethead extruded parts, as well as several of the other products he has- will be delivered today, so haven't seen the quality, but other folks say they're great. After spending several hours on the horizontal stabilizer attach brackets, then misdrilling one of the holes, $20 for the set of HS brackets is just the right prove!
phil
RV10
KSLC
"McGANN, Ron" <ron.mcgann(at)baesystems.com> wrote:
[quote] All,
LIKE2LOOP(at)aol.com Guest
Posted: Wed Sep 20, 2006 1:19 pm Post subject: Safety Alert WD-415 weldment |
In a message dated 9/17/2006 10:17:29 PM Eastern Standard Time, armywrights(at)adelphia.net writes:
| Quote: | | when Vic completed his plane the parts available were only welded on the one side of the nut. Since then the nuts come welded on both sides. Good judgment always prevails, but with the new welded type there may be no structural reason to use the extruded aftermarket brackets. |
The all aluminum (after kit market) parts are MUCH thicker, more threads to grip, no weld to break (or adjacent weak metal) and have a much more solid base that will accept a countersink and allow the cover plate to be dimpled and flush riveted. This is a no brainer to buy the part for a few bucks and get peace of mind and a better part.
Steve
Stephen G. Blank,DDS
RV-10 #40499 Finishing the Elevators
Cessna 170b Flyer
Port St Lucie, FL
772-475-5556 cell
