Charles Heathco
Posted: Mon Sep 18, 2006 8:11 am Post subject: 6a strut bolts |
I thought I would pass this on FWIT. I spronged my nose wheel last thur eve and was concerened about the result so I found two problems actually I dont think were related. I thing no harm done on the sprong, but Ifound that with the spacer washer on the axel, I had too much play on bearings so I took it off which resulted it it being a bit tight, but good and solid. I also found a bit of rotation on the nose strut in the engine mount and when I checked the bolt, I found it not much more that barley tight. I couldnt get a torque wrench on it so I tighted it to estimated "Guttentite". I then checked the mains and found them also pretty loose. You might want to check yours. Charlie Heathco
