tgesele(at)optonline.net Guest
Posted: Fri Sep 15, 2006 12:48 pm Post subject: Plexi Attach |
Has anyone used an alternate method of attaching the windows/windscreen to
the cabin cover on the -10? Any comments pro/con specifically relating to
using epoxy for the bonding with an layer of cloth on top to try and prevent
the paint cracking issue would be greatly appreciated.
- Tom Gesele #473
rvbuilder(at)sausen.net Guest
Posted: Fri Sep 15, 2006 1:18 pm Post subject: Plexi Attach |
I gave some serious thought to using Sikaflex which is very popular with
the canopy guys on the 2 seat models. For some reason I ordered the
Weldon when I was batch ordering though so I guess I'll probably go with
that.
Michael Sausen
-10 #352 Fuselage
zackrv8
Posted: Fri Sep 15, 2006 6:55 pm Post subject: Re: Plexi Attach |
Tom,
Use this stuff. After it cures, it stays flexible somewhat. Kitfox uses this stuff to bond the ribs onto the spar. I use it to bond my skins to the ribs (and then rivet them the next day). Several of my friends have bonded their RV8 canopy's to the frame with this product. I will use it to bond my windows on my RV10. May be better than Sikaflex. Don't know for sure because I have never used Sikaflex. Picture below.
You can get it at MSC.
Zack
Description: |
Filesize: |
66.29 KB |
Viewed: |
264 Time(s) |
_________________ RV8 #80125
RV10 # 40512 |
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Fri Sep 15, 2006 7:53 pm Post subject: Plexi Attach |
FYI: Attached is the info sheet from 3M on the Scotch-Weld 2216 mentioned
below.
Kevin
40494
tail/empennage
Sent: Friday, September 15, 2006 7:55 PM
Subject: Re: Plexi Attach
Quote: |
Tom,
Zack
RV8 #80125
RV10 # 40512
_________________ Kevin
40494
do not archive |
