rjdaugh
Posted: Fri Sep 15, 2006 2:59 pm Post subject: Annual on Kitfox III - Repairman Experimental Aircraft Build |
Marco is right. If you don't get a certificate for "Repairman Experimental
Aircraft Builder" you can't do the condition inspection.
You don't get them automatically. You have to apply for the certificate.
If you have a good DAR, he will help you get when your plane is inspected.
But you need one to put with your signature when you do the annual condition
inspection.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
