Oldsfolks(at)aol.com Guest
Posted: Sat Jan 21, 2006 5:55 pm Post subject: >Re: I HATE PINHOLES |
Boy !! ME TOO !!!
I hate fibreglas in any form but we have to suffer through it .
I finally found out about Ploy Fibre "Smooth Prime " ,after I had my
fingers bleeding just from sanding the parts the air sander couldn't reach !!
I really regretted not knowing about "Smooth Prime" sooner. A couple of
coats , with easy sanding & it is done. NO PINHOLES !!!!!!!!
Try it - you'll like it.
Bob Olds RV-4 , N1191X
A&P , EAA Tech. Counselor
Charleston,Arkansas
Real Aviators Fly Taildraggers
Painless
Joined: 10 Jan 2006 Posts: 40 Location: Peshtigo, Wisconsin
Posted: Sat Jan 21, 2006 7:24 pm Post subject: >Re: I HATE PINHOLES |
Bob:
How much Smooth Prime did you go through? Did a quart do the job or did you
need more than that? I am trying to apply your experience to a 6A cowl.
Jeff Orear
RV6A N782P (reserved)
Darn close to inspection time..
Peshtigo, WI
_________________ Jeff Orear
RV6A N782P
Peshtigo, WI |
rice737(at)msn.com Guest
Posted: Sat Jan 21, 2006 9:31 pm Post subject: >Re: I HATE PINHOLES |
Where can you get smooth prime?
Paul
RV8QB
gerns25(at)netscape.net Guest
Posted: Sat Jan 21, 2006 10:24 pm Post subject: >Re: I HATE PINHOLES |
Here is another area where they RC jet guys have figured it out. There is a product that I have used on 4 radio controlled fiberglass jets made by Bob Violet Models (www.bvmjets.com) that is a paste of sorts that is simply rubbed on, allowed to dry, and then rubbed off using a paper towel. This paste is about the consistency of paste car wax. It works awesome on pinholes and is used before primer. I think it is called "BVM Pinhole filler"...Wow, isn't that creative! One would need to buy a couple cans of it as the cans are relatively small. Like I said, I have used it before and it works very well and is simple and quick. I plan on using this when I do my cowl and other fiberglass parts on my RV7. Just another option out there.
Darin Hawkes
RV7 N619PB res.
Waiting for Wing Kit
sears(at)searnet.com Guest
Posted: Sun Jan 22, 2006 1:59 am Post subject: >Re: I HATE PINHOLES |
| Quote: | Boy !! ME TOO !!!
| Quote: | I really regretted not knowing about "Smooth Prime" sooner. A couple of
Unfortunately, I didn't have the same results as Bob. I ended up sanding
almost all of the Smooth Prime off of my fiberglass parts and lost about a
week of work doing it. I ended up using a fast fill primer made by the same
company that made the rest of my finishing products. It may have been
DuPont; but, it may also have been PPG. I'm sure all of them make a fast
fill primer. While spraying this thick primer on, I could spread it into
the pin holes nicely with my fingers and filled them easily in a couple of
coats. The nice thing is that the stuff is compatible with the rest of the
paint, can fill in minor dings easily, is wet sandable (which was the
problem I had with Smooth Prime), can fill up to 1/16" thick, and does not
seem to run. I'll be using the same primer, this time. I seem to have a
few dings to fill.
Others have had very good luck with Smooth Prime; but, you do have other
choices
that may be more easily obtained.
Jim Sears in KY
RV-6A N198JS (Scooter)
RV-7A #70317 (Skinning wings, etc.)
EAA Tech Counselor
rv9jim(at)juno.com Guest
Posted: Sun Jan 22, 2006 6:06 am Post subject: >Re: I HATE PINHOLES |
Jeff,
I built a glass airplane and "Smooth Prime" is the best pin hole
filler. Its water based and is rolled on with a small foam roller. You
will roll on several 4 to 6 layers of smooth prime only to sand it off.
The stuff drys quickly ( in several hours in the warm south) and allows
you to put on at least two applications a day. The key is when your
done, let the items you filled "dry" for several weeks before painting.
You can use aux heat to speed it up. The reason is to remove the water
left in the smooth prime after finishing. Then you can paint it. I
recommend you use a misting of black lacquer to provide an indicator of
how you have left the surface. If any paint is left on the surface
after sanding, you did not sand that area. So more smooth prime is added
to raise the lower surface. It leaves a very nice surface. You can
become quite anal on how nice you want the surface to look. In other
words, "more is better, too much is enough"
Jim
Painless
Posted: Sun Jan 22, 2006 6:34 am Post subject: >Re: I HATE PINHOLES |
Thanks Jim. I have heard that guys have had trouble getting rid of
pinholes, so your advice is appreciated.
Jeff
RV6A N782P
Peshtigo, WI |
lifeofreiley2003(at)yahoo Guest
Posted: Sun Jan 22, 2006 6:56 am Post subject: >Re: I HATE PINHOLES |
www.polyfiber.com/uvsmooth/
Darrell
Paul
RV8QB
shempdowling2(at)earthlin Guest
Posted: Sun Jan 22, 2006 7:28 am Post subject: >Re: I HATE PINHOLES |
I ordered it last night. Thanks
Shemp/Jeff Dowling
RV-6A, N915JD
235 hours
Chicago/Louisville
Posted: Sun Jan 22, 2006 8:06 am Post subject: >Re: I HATE PINHOLES |
So after putting on 3 or 4 coats of primer, do I sand it down or leave it
sit for a couple of weeks before misting on the lacquer?
Is the lacquer being used as the indicator for high/low spots?
When doing wheel pants or any very curved parts, whats the best way to sand
them? Ive been using a wall board sander with a rubber mat you get at any
hardware store. Ive been using no finer than 100 grit, hoping the high
build primer will cover the sanding marks. I was told to try and use the
largest sanding block you can for evenness, although I have a feeling Im
going to have to use my palm for the final sanding.
Shemp/Jeff Dowling
RV-6A, N915JD
235 hours
Chicago/Louisville
lhelming(at)sigecom.net Guest
Posted: Sun Jan 22, 2006 11:34 am Post subject: >Re: I HATE PINHOLES |
Posted: Mon Jan 23, 2006 2:45 am Post subject: >Re: I HATE PINHOLES |
| Quote: | Jim, glad you made the statement about smooth prime not being wet
sandable.
| Quote: | It is not wet sandable. It MUST be dry sanded as the directions on the
can
Larry's right. At the time I used it, I had the can and the instruction
manual. Maybe it was assumed I'd dry sand. The instructions said nothing
about it. Since we do a lot of wet sanding on RV's, that's what I did with
the Smooth Prime. What scared me about the stuff was that it would raise in
tiny bubbles while being sanded. Those would leave pock marks about the
size of pin heads. I then tried dry sanding the stuff; but, I was afraid
the lifting would also happen while paint was being applied. It's wet,
also. I got rid of it and went with a fast fill primer, instead. If I ever
build a glass airplane, I may try Smooth Prime, again; but, there's a very
slim chance I'll build a glass airplane. In the meantime, I'll use the fast
fill primer that matches the paint I'll be using.
I just thought I'd let our folks know that not all are happy with the stuff.
It does have drawbacks.
Jim Sears in KY
