dcsfoto
Posted: Sun Sep 10, 2006 4:59 pm Post subject: Header Tank |
Just got my first Kitfox a Model III. It is 14 years old and has no header tank. I just got a used header tank from a model IV . my manual shows the header vent hooked to a vent line in the right tank,my right tank has no vent hookup.
Do I need a vent line on my header tank?
kirkhull(at)sbcglobal.net Guest
Posted: Sun Sep 10, 2006 6:39 pm Post subject: Header Tank |
Yes or the tank will not fill up with fuel properly as the air will have no
way out of the tank.
Beemer
Joined: 26 Aug 2006 Posts: 87 Location: Middle Georgia
Posted: Sun Sep 10, 2006 7:02 pm Post subject: Header Tank |
Yes, though I refer to it as a "purge" line.
My Model 2 has the line going to an ON-OFF valve, and vented overboard. If
my lo-fuel light in my header tank ever comes on, I simply open the valve
until it goes out. Positive pressure from the tank, and suction from the aft
facing vent tube fills the header quickly.
I highly recommend a similar system to you.
Bradley
_________________ Beemer
KF2 (and now an M3!)
Suzuki G10 three-banger
Middle Georgia |
rliebmann(at)comcast.net Guest
Posted: Sun Sep 10, 2006 7:41 pm Post subject: Header Tank |
When I built my Model 2 back in 1991 I installed a Facet fuel pump and fuel
pressure gauge just in case....Before each days flight I open the valve
between my header vent tube and the fuel return line that goes back up to my
right wing tank and I turn on the fuel pump. That purges any & all air from
the header tank. Then, with the pump still on, I shut that valve which then
pressurizes the lines to the carbs. My engine starts are always fast since I
have 3# of fuel pressure at the start.
I would never fly without the Facet and the pressure gauge.
Ron N55KF 582/C box
| Quote: | Yes, though I refer to it as a "purge" line.
aft
Bradley
FLIER(at)sbcglobal.net Guest
Posted: Sun Sep 10, 2006 9:33 pm Post subject: Header Tank |
The header has to vent to fill properly. You'll need
a vent.
Ted
--- Original Message ---
Subject: Header Tank
<david(at)kelm.com>
_-
browse
Subscriptions page,
FAQ,
List
| Quote: | _-
Web Forums!
| Quote: | _-
| Quote: | _-
Admin.
| Quote: | _-
smokey_bear_40220(at)yaho Guest
Posted: Sun Sep 10, 2006 9:37 pm Post subject: Header Tank |
I agree, the header vent is essential.
I haven't done this, but it is an idea. You could "T"
off of the upper tank sight gauge port to a vent line
from the header, thus avoiding having to drill and lay
up a new tank port. Takes a little plumbing, but
should be easier???
Anyone think of a significant problem with this
approach? It is past my bedtime, by a few years.
Kurt S.
--- dcsfoto <david(at)kelm.com> wrote:
| Quote: | Just got my first Kitfox a Model III. It is 14 years
pwmac(at)sisna.com Guest
Posted: Mon Sep 11, 2006 7:31 am Post subject: Header Tank |
It is mandatory
Paul
At 06:59 PM 9/10/2006, you wrote:
http://forums.matronics.com/viewtopic.php?p=60857#60857
