Glenn Horne
Posted: Sun Sep 10, 2006 9:01 am Post subject: spark plugs |
Glenn Horne here,
Can anyone on the list tell me the firing order of the 582 and the
spark plug gap? Have to see the FESDO tomorrow and need this.
Have the engine manual but don't seem to fine it in there.
GlennHorne
Suffolk, Va
Kitfox II 582.
dave(at)cfisher.com Guest
Posted: Sun Sep 10, 2006 9:37 am Post subject: spark plugs |
582 plug gap .018
only two cylinders so pick 1 -2 or 2 -1
Spark plugs BR8ES
occom
Posted: Sun Sep 10, 2006 10:05 am Post subject: spark plugs |
The spark plug gap is 0.5 mm or .02". The firing order is of course 1-2 on a two cylinder engine but in fact all plugs fire at the same time at the top and bottom of each stroke.
Glenn Horne
Posted: Sun Sep 10, 2006 1:43 pm Post subject: spark plugs |
Thanks Dave.
Glenn
Posted: Sun Sep 10, 2006 5:35 pm Post subject: spark plugs |
Dave,
582 plugs should be gapped .016 to .020 . I use .018 and if you gap at the max gap setting you will not allow any margin for wear .
Dave
