janderson412(at)hotmail.c Guest
Posted: Sun Sep 10, 2006 6:05 pm Post subject: Synthetic oils |
I've been told semi synthetic is ok with 100LL? Is this correct?
Subject: Re: Question on oil
Date: Sun, 10 Sep 2006 08:54:02 -0700
Dee,
The value in a full synthetic is the higher temps they can tolerate, the hit
is their inability to keep the lead residues in suspension. If you fly
strictly with car gas, the syntheticsynthetic should be fine. If you
occasionally use 100LL then you might want to avoid synthetics. This from
the Rotax oil recommendation bulletin. The Rotax 912 series engines use the
same oil in the engine as well as the gear box so they recommend a
motorcycle engine oil with the gear additive. If your engine is similar,
you might want to check the Rotax owners association website for info.
Lowell
pwmac(at)sisna.com Guest
Posted: Mon Sep 11, 2006 7:31 am Post subject: Synthetic oils |
Yes, with shorter oil changes. Also use the additive, like the spam
can guys do.
Paul
Dee,
the hit is their inability to keep the lead residues in
suspension. If you fly strictly with car gas, the
syntheticsynthetic should be fine. If you occasionally use 100LL
then you might want to avoid synthetics. This from the Rotax oil
recommendation bulletin. The Rotax 912 series engines use the same
similar, you might want to check the Rotax owners association website for info.
Lowell
