wayne.e(at)grandecom.net Guest
Posted: Fri Sep 08, 2006 3:02 am Post subject: Paint $$Build times - time to get restarted? |
The person I will use, Glo Custom Paint, has only painted one 10 and that is Russ's but he's done a ton of RV's. I'm in the queue at $8,000. Based on the planes I've seen Grady paint, which is quite a few, he really does excellent work.
Wayne Edgerton #40336
jdalton77(at)comcast.net Guest
Posted: Fri Sep 08, 2006 7:48 am Post subject: Paint $$Build times - time to get restarted? |
Wayne,
Is he priming for you also? $8k seems high if you've already primed and there is no paint removal like an older plane getting a paint job. Will you be disassembling and re-assembling the control surfaces? If yes, then it really seems high.
I know he does good work though.
Posted: Sat Sep 09, 2006 3:31 am Post subject: Paint $$Build times - time to get restarted? |
I deliver the plane to him with no primer and walk away. He does all the disassembling and reassembling. I check around a little bit and I think he has a fair price for the quality of work that he does. I know of one 10 builder who paid $14,000 for his paint job, ouch. I think he's charging around $6,000 for the RV6's and 8's.
I just want someone to paint my plane that I know does excellent work and that's Grady.
carl.froehlich(at)cox.net Guest
Posted: Sat Sep 09, 2006 4:33 am Post subject: Paint $$Build times - time to get restarted? |
I painted my RV-8A - paint alone cost $2500 (I did some hard colors). $6000 for someone to do everything sounds like a really good deal.
Carl Froehlich
RV-8A (270 hrs)
RV-10 (tail cone)
[quote] --
AV8ORJWC
Posted: Sat Sep 09, 2006 5:52 am Post subject: Paint $$Build times - time to get restarted? |
RV builders tend to bring a different conservative bent to pricing of final topcoats. Tom Conner in Bend charges the Lancair guys upwards of $26,000 all the way above $34,000 to meet the definition of excellent work. He is more than 24 months backlogged. True, all composite skins require lots of correction and fill. Thank goodness for 2024 and flush rivets. The EPA rules and charges have pushed the chemicals into a pricing schedule which exceeds VNE. If anyone has missed Scott Schmidt’s latest web post “Going to the Hangar”, you will see the new benchmark on RV-10 Topcoats. My guess is that Ray and Scott chose to delay the unveiling until they can sweep Grand Champion next year at OSH.
Our local guy is retiring cause he has gotten tired of the tremendous amount of prep required to take it from “drop off” to “excellent”. He won’t use immigrant labor to complete the mundane tasks. On a separate note, Tim Olson posted the most cost effective way to get to a great paintjob at the lowest cost by doing the right steps. We have lots of choices. And then there is Checkoway who will never finish from the primer/bare Alclad stage.
Paint Envy anyone?
John Cox
Do not Archive
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Saturday, September 09, 2006 4:31 AM
Subject: Re: Paint $$Build times - time to get restarted?
[quote] [b]
dav1111(at)cox.net Guest
Posted: Sat Sep 09, 2006 1:00 pm Post subject: Paint $$Build times - time to get restarted? |
That is the reason why Grady O'Neal at GLO Custom Paint is booked up through July of 2007. I know because an RV-8 I am helping finished up just booked his paint date and the earliest he could get with Grady was July 2007!!!!
If you want the best at a reasonable price you really have to plan ahead. I booked my paint date (currently in Grady's paint booth) January of 2006. Grady requires a 10% deposit to hold a paint date.
Pictures should be posted by next week.
Russ Daves
N710RV (RV-10 Flying)
gorejr(at)bellsouth.net Guest
Posted: Sat Sep 09, 2006 4:46 pm Post subject: Paint $$Build times - time to get restarted? |
Where is Grady located? Jim
Date: 2006/09/09 Sat PM 05:00:03 EDT
Russ Daves
Posted: Sun Sep 10, 2006 2:15 am Post subject: Paint $$Build times - time to get restarted? |
Northwest Regional Airport 52F, just north of Ft. Worth, Texas.
Russ Daves
N710RV flying
DO NOT ARCHIVE
Posted: Sun Sep 10, 2006 4:50 am Post subject: Paint $$Build times - time to get restarted? |
He's located in Roanoke, TX, which is just a little bit north and west of the DFW airport.
Here is a web address for Northwest Regional where Grady is located.
http://www.nwratx.org/
