Posted: Fri Sep 08, 2006 4:10 am Post subject: Squeezer technique- was New Builder |
Hi All-
| Quote: | ...The pneumatic squeezer permits one hand to hold parts...
... it also provides consistency with the appearance of the numerous
rivets that is difficult
| Quote: | to achieve with a hand squeezer.
Well, this squeezer thread has got me curious as to how people are using
their hand squeezers and having difficulties. I only have experience with
one pneumatic squeezer, but it most definitely required two hands to
operate, and none on the parts. It was a large, heavy unit.
When using my Avery hand squeezer, I initially adjust it so that with the
dies just closed on an unset rivet, the handles form about a 20 degree
angle. This allows me to hold the squeezer (choked up) in one hand and the
parts in the other. I squeeze the rivet just enough to hold the parts in
the proper relationship. I can then grip switch, if desired, to something
more comfortable. I incrementally adjust the ram until the rivet is set
correctly when the squeezer is operated to the stop. Thus, all the rivets
in a series come out with perfect consistency, and with no extra effort.
The only time I've had an issue using the hand squeezer was in mounting rod
end adaptors into the control system tubing. I believe the cleating I
experienced would have been the same with a pneumatic unit, and the problem
was rectified by putting the part in a padded vise.
I hope this is of use-
gm
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
bfilipiak(at)yahoo.com Guest
Posted: Fri Sep 08, 2006 7:25 pm Post subject: Squeezer technique- was New Builder |
I use both. The yokes are interchangeable too. I got
them from Avery and use the pneumatic quite easily
with one hand. It is big and heavy, and my arm will
start to get tired after about 100 rivets, but I do
find it quite simple. It does take sonme getting used
to though, finessing the thumb lever in all attitudes,
upside down, backwards, left handed, using different
fingers, etc.
There are times though, that it just won't fit, and
the hand squeezer fits nicely. I then have to use the
hand squeezer, where my arms are tired after about 5
rivets. You do need to be extra cautious when using
the hand squeezer. Be sure the rivet is sitting in
the hole properly before you squeeze it enough to lock
it into place.
I reach for the pnuematic first. If it doesn't fit,
I try the hand held. If it won't work, I consider the
C-frame. After that, I weigh other options depending
on the situation.
Best of luck to all,
Bart Filipiak
Empennage done, Left wing nearly done.
--- glen matejcek <aerobubba(at)earthlink.net> wrote:
Hi All-
parts...
heavy unit.
about a 20 degree
gm
browse
Subscriptions page,
FAQ,
Web Forums!
Admin.
