ATG goes w/ Op Tech
Deems Davis
PostPosted: Wed Sep 06, 2006 6:25 am    Post subject: ATG goes w/ Op Tech Reply with quote
FYI, Another vendor just made Op Tech their EFIS. Here's a link from
Aero News announcing ATG's decision to make Op Tech their Glass panel
vendor:
http://www.aero-news.net/index.cfm?ContentBlockID=98e9caf0-593b-4468-9030-528ee62b8329&#d
Deems Davis # 406
Wiring Op Tech Panel
http://deemsrv10.com/
jump2(at)sbcglobal.net
PostPosted: Wed Sep 06, 2006 10:37 am    Post subject: ATG goes w/ Op Tech Reply with quote
Deems, I got OP Tech efis intergrated system at Sun n Fun and having my panel cut this week. At Oshkosh We bought a Pcas system XRX by Zaon, Using it in my C310,and got OP( DEXTER) and them to talk. Dexter is suppose to see if we can get it talking and diplay on the screeen FYI. It has a 232 port.
I finally bought a power supply and fired up both displays, They look pretty good if I say so myself.
Pat Thyssen
Houston area #257
Deems Davis <deemsdavis(at)cox.net> wrote:
[quote]--> RV10-List message posted by: Deems Davis
Aero News announcing ATG's decision to make Op Tech their Glass panel [quote][b]
greytex
PostPosted: Wed Sep 06, 2006 11:08 am    Post subject: ATG goes w/ Op Tech Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Pat, what part of the Houston area are you. We are going to be building there also.
John Cram
40569 Emp.
Deems Davis
PostPosted: Wed Sep 06, 2006 4:38 pm    Post subject: ATG goes w/ Op Tech Reply with quote
I'm in the process of wiring my panel for dual Op Tech portrait
screens. (non-integrated with a Garmin stack + Freeflight WAAS). I've
had the power to them several times, and run them in DEMO mode for
hours. I have NO experience in ANY glass/EFIS environment, so I don't
have any frame of reference for Op Tech vs Chelton or any other EFIS/MFD
but I"M TOTALLY BLOWN AWAY by the functionality that I see here. I love
how you can get Sooooo much info presented on a single screen, and then
you can configure the other screen for full page views, etc. or you can
have them mirror the main. I also love the embedded IFR charts, I've
"flown' several approaches in DEMO mode and it's so cool the way if
flies the approach as well as the 'missed' and it shows you your
progress (on the chart) down the approach path (vertically and
horizontally!). I believe that this potentially can/will take a lot of
the workload out of IFR.
RE XRX , if ZAON has an RS 232 hardware interface it should just be a
matter of software for Dexter. I hope they do it!
Are you doing your own install? Please keep us posted on your progress.
I'm not to the point where I'm ready to power things up yet, and all of
this wiring stuff is a whole new set of skills I'm learning/slowly
acquiring.
Deems Davis # 406
Fuse
Pat Thyssen
Houston area #257
PostPosted: Thu Sep 07, 2006 3:47 am    Post subject: ATG goes w/ Op Tech Reply with quote
I'm at David Wayne Hooks airport, Northwest corner of HOUSTON, between Spring and Tomball. What about Yourself?
Pat Thyssen 257
John Cram <johncram(at)msn.com> wrote:[quote] <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Pat, what part of the Houston area are you. We are going to be building there also.
John Cram
40569 Emp.
greytex
PostPosted: Thu Sep 07, 2006 12:43 pm    Post subject: ATG goes w/ Op Tech Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I know exactly where Hooks is. We have not moved to Houston yet, but will very soon. BTW we are also going with OP dual screens.
