rv9jim(at)juno.com Guest
Posted: Sun Jan 22, 2006 6:06 am Post subject: I HATE PINHOLES |
Poly fiver is the supplier of "Smooth Prime"
Jim
Oldsfolks(at)aol.com Guest
Posted: Sun Jan 22, 2006 1:28 pm Post subject: I Hate Pinholes |
You can get "Smooth Prime " from Aircraft Spruce. Look in the fibreglas
section of their catalog - not in paint & primer.
Mix it in small (2 oz.) or so batches, it goes a long way and is too
expensive to waste.
Prepare for a snow storm in the shop,it sands off in lots of white stuff.
Bob Olds RV-4 , N1191X
A&P , EAA Tech. Counselor
Charleston,Arkansas
Real Aviators Fly Taildraggers
Posted: Sun Jan 22, 2006 4:11 pm Post subject: I HATE PINHOLES |
Hi Jeff
You sand the first coatings down to the base material after
letting it dry for 6 to 8 hours. Then reapply another 3 to 5 coats and
let it dry over night. In the morning, sand it down again. With the
black lacquer misted over the coating before you sand, the black lacquer
will indicate where you have a low area. Continue this way until you
have the surface that you want. I had some areas on my Europa that
required some extra filling so I probably coated some areas 5 or 6 times
to bring it to the level and finish I wanted. I used a random orbital
sander to knock the smooth prime down. It comes off quickly with 180
grit (? if I remember- its been 4 years ago). It will be pin hole free
and look great. As I mentioned before, when you reach the end, let it
dry completely. At that point, you can put the primer coat on for the
paint you have chosen. There are many primer/fillers but most of them are
solvent based. The smooth prime is water based which is great. Only
required the stink paint primer once with a small bit of sanding and then
on to the colors---
Jim
Posted: Sun Jan 22, 2006 4:20 pm Post subject: I HATE PINHOLES |
Jeff,
Yes, the black lacquer is the indicator for low and hi spots. If
you are doing straight areas, then a sanding board will keep things flat.
Other than that, I used a small mouse pad like foam pad that I used
sticky back sanding paper attached to do the curvy portions. Some times,
fingers were necessary in some small areas. Its not all that bad.
considering I'm trying to bend the da-- frame on my slider to match the
curvature of the fuselage. Now that is (at)%
*$#(. I decided to slit the
square tubing in several places to get it to be in shape and then get it
welded back.
Jim
khorton01(at)rogers.com Guest
Posted: Sun Jan 22, 2006 5:42 pm Post subject: I HATE PINHOLES |
On 22 Jan 2006, at 19:08, James H Nelson wrote:
Hi Jeff
and
How accurate do you need to be when you mix the two parts of the
Smooth Prime? The directions make it seem like you need to be very
precise, which doesn't seem easy if you do many batches.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
deruiteraircraftservices( Guest
Posted: Mon Jan 23, 2006 1:42 am Post subject: I HATE PINHOLES |
Akzo Aerospace Finishes does a product called "static conditioner". It's a
white milky thick liquid that is applied by brush in circular motions or by
squeegee. Let it dry for about an hour and remove excess by scotchbrite. Do
not use blown gun but use a tackrag. Then apply a coat of Laminar X500
surfacer which will seal in the static conditioner and provide a real hard
surface to sand or paintprep on so that one doesn't sand into the fibers of
the cloth. Maybe not cheap, but fast and effective. It's used among other on
Boeing and Bombardier compositesamong other applications.
The static conditioner is applied straight out of the tin, just stir before
use. A litre of each should be sufficient for both cowlings and the roof
(RV10) and wingtips
If you use any other filler, make sure it's in near liquid state so that the
product can be either forced into the pinhole or run into it. If not, the
product will "bridge" the hole and when you ssand open up again, with the
added bonus of eventually damaging the fibers by repeating the procedure a
number of times.
For effective filling, use a crosscoat system,similar to when you're
spraying.
