gretzgretz
wayne.e(at)grandecom.net
PostPosted: Fri Sep 01, 2006 2:29 am    Post subject: gretzgretz Reply with quote
You know for what ever it's worth I also went with the Gretz pitot tube, I liked the idea of the auto on feature, and I installed the controller for it right on the back of the inspection plate right next to where it's mounted. I've attached a picture. I think it will make it very easy to work on if necessary.
Also I think the tube is just a tad bit ugly so I call the owner who sells the Gretz unit and ask him if I could paint it and he told me that's not a problem. He said I could sand down the unit to smooth it up a little. I also talked to my paint guy and he said not a problem to paint it. Maybe if I paint it, it will blend into the underside and not look quite so ugly :>}
Wayne Edgerton #40336
 Filesize:  116.94 KB
 Viewed:  178 Time(s)
