Wiring Diagram and Software
ericparlow(at)hotmail.com
PostPosted: Wed Aug 30, 2006 4:33 am    Post subject: Wiring Diagram and Software Reply with quote
Two questions:
1.) Does anyone have a detailed wiring diagram available for reference and
to use as a template based on the Aeroelectric recommendations?
2.) What software is available to make detailed wiring diagrams at a
reasonable cost?
ERic--
40014
N104EP
RV-10 Avionics
Rick S.
PostPosted: Wed Aug 30, 2006 5:27 am    Post subject: Wiring Diagram and Software Reply with quote
Eric,
Just in case you only have the book, got to the attached link and check out these diagrams. Especially Z-14 and Z-19 under DC power. Short of giving you the wiring diagrams for your avionics harnesses you should be able to wire the entire aircraft with the info in these pages.
If it seems greek to you seek help from your local builder or ESS chapter. Bob's book is great on theory and short on actual "how to's".
Many of the RV-10 and other RV builder sites have their own diagrams and power distribution for you to "borrow" for ideas Wink
Tim has a Z diagram and William Curtis has a good schematic as well.
http://www.aeroelectric.com/PPS
Rick S.
40185
Rick S.
RV-10
40185
