firewall eyeball question
jaybrinkmeyer(at)yahoo.co
PostPosted: Mon Aug 28, 2006 7:42 am    Post subject: firewall eyeball question Reply with quote
I'm wanting to install firewall eyeballs in my firewall before attaching the
side skins... The Vans store lists:
Steel Bulkhead Fitting -- Part No: EYEBALL SE961-125S
Bulkhead carry through assembly for control cables or wiring. Hole size 1/8",
can be enlarged up to 0.26" as required.
Does anyone know if this part provides adequate hole clearance for the ($500!)
Vans RV-10 throttle quadrant cables?
At the risk of starting a flame war... SS eyeballs are preferred, right?
Jay
Slooow building everything
mike(at)cleavelandtool.co
PostPosted: Mon Aug 28, 2006 8:12 am    Post subject: firewall eyeball question Reply with quote
We sell both the Steel (plated not stainless) and the Aluminum pass-through.
Both can be enlarged, but the Aluminum come out much nicer. My theory is
that if you burn through the 3/4" of Aluminum, you have a bigger problem
(like all of the 1/8" rivets going through the firewall). I don't know but
I would guess the cables are larger than 1/4". The Aluminum eyeball you can
drill up to 5/8" before running into problems.
Mike Lauritsen
Cleaveland Aircraft Tool
2225 First St.
Boone, Iowa 50036
515-432-6794
mike(at)cleavelandtool.com
