pwmac(at)sisna.com Guest
Posted: Mon Sep 04, 2006 5:58 am Post subject: Fuel feed problem vent for Kirk |
Here is a repeat of the vent pics for "kirkhull"
I added some comments below.
Paul
Yes the vent is at the top of the tank under the
flange. One can use a swivel 90 deg fitting. Some
have female threads so one has to use a close
union In any event they are available. Check
hydraulic supply houses. Check the car nut places
like Earls. Attached is a couple of pics for an
even easier way using AN fittings & a straight
swivel from the hydraulics house + soft Al tubing.
Paul
PS, The hydraulic people only sell cad plated
steel fittings with the AN 37 deg flare.
PPS, I used a 90 deg bulkhead hyd fitting for the
fuel line where it penetrates the firewall. A
good upgrade for fire protection wherein it replaces the kit aluminum one.
PPPS,
With regard to the original issue of unequal tank
feed - Don is probably correct in that the
partially blocked vent is not the problem. Having
said that I sure would not want my vent line to
have any issues which is why I used the 90 deg fitting and SAE vent hose.
At 03:04 PM 9/2/2006, you wrote:
Paul-
In my IV tanks, made in 1994, the vent opening
is so close to the top flange of the tank that
it would be impossible to use a 90° fitting,
because you would not be able to rotate it.
Where did you hear about "the preferred 90
degree fitting"?...and what makes it preferable?
Lynn
On Saturday, September 2, 2006, at 09:22 AM, PWilson wrote:
>Good point. It sounds like he used a straight
>fitting instead of the preferred 90 degree
>fitting at the vent to tank connection.
> Paul
>At 06:57 AM 9/2/2006, you wrote:
>>Roger, it sounds like your right side fuel
>>vent is blocked. It prevents air entry and so
>>retards fuel flow but at some point fuel does
>>flow some and this creates a vacuum that sucks the fuel from the other side.
>>Barry
28.59 KB |
257 Time(s) |
28.61 KB |
349 Time(s) |
kirkhull(at)sbcglobal.net Guest
Posted: Mon Sep 04, 2006 11:07 am Post subject: Fuel feed problem vent for Kirk |
thanks
