coop85(at)bellsouth.net Guest
Posted: Sun Aug 27, 2006 12:17 pm Post subject: Avionics cooling |
I have 12 hours on the RV-10 and for the most part all is going well. I
have a fairly warm tunnel that I'll apply the techniques offered here to
fix. I have two other issues I'll address in separate messages.
My avionics are getting REALLY warm, in fact the DYNON is running really
slow (hit the timer function and it counts up at about 30% normal speed).
What sort of methods are you guys using to keep things under control. I
remember several comments about computer fans and that seems like a good
idea. I also considered running a blast tube off the ventilation scoop and
direct fresh, cool air behind the panel at a slight loss to passenger
comfort.
Marcus
ScooterF15
Posted: Sun Aug 27, 2006 1:00 pm Post subject: Avionics cooling |
Marcus,
I have a transponder that is overheating. As a temporary fix, I did exactly what you mentioned. I connected a piece of scat tubing to the passenger vent with a hose clamp and pointed it up toward the stack under the panel. Incidentally, I have been able to keep passengers happy in hot weather by pointing the left side vent across the cockpit.
As a more permanent fix I plan on installing some strategically mounted computer fans.
Jim
In a message dated 8/27/2006 4:19:54 P.M. Eastern Daylight Time, coop85(at)bellsouth.net writes:
Quote: | --> RV10-List message posted by: "Marcus Cooper" <coop85(at)bellsouth.net>
comfort.
Marcus
Do not es Day --> - NEW MATRONICS WEB FORUMS -
bsp; --> nbsp; - NEW MATRONICS LIST WIKI -
_-= ; p; - List Contribution Web Site ; =========================
jesse(at)itecusa.org Guest
Posted: Sun Aug 27, 2006 5:47 pm Post subject: Avionics cooling |
We have installed an AmeriKing cooling fan 3 or 5 ports with lines running
to the back of the radio stack, but nothing for the Dynons. Haven't had any
problems. Do you have a way of checking the temp at specific places behind
the instrument panel to make sure it is heat that is causing the problem in
the Dynon? I would agree that running a decent sized hose from the right
side air vent to somewhere behind the panel for a flight might narrow down
the possible problems.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Posted: Sun Aug 27, 2006 6:09 pm Post subject: Avionics cooling |
I think I'll order the cooling fan as well, probably should have done that
from the start but it didn't even occur to me.
One detail I didn't include on the Dynon, it actually did it's "I'm really
getting hot here" trick where it turns grayscale and says the temp is too
hot. I'll try ducting some air short term while the various fans show up.
Marcus
Tim(at)MyRV10.com Guest
Posted: Sun Aug 27, 2006 6:37 pm Post subject: Avionics cooling |
Marcus,
I got a 3 output avionics cooling fan too. It's probably a
worthwhile investment.
Marcus
Ray.R.Doerr(at)sprint.com Guest
Posted: Mon Aug 28, 2006 8:56 am Post subject: Avionics cooling |
I have the 3 port ameriking fan which connects to both 430's and the transponder, but both of my Dynon's (small versions) don't have any cooling and I've found that in the hot sun while flying the EFIS which is mounted at the top of the panel is alarming with high internal temp and the screen changes to a gray scale instead of the normal color screen. In working with Dynon, they said it will still function but is outside the temperature limits in which they calibrated the unit, so it may not be as accurate.
Thank You
Ray Doerr
Tdawson(at)avidyne.com Guest
Posted: Mon Aug 28, 2006 9:00 am Post subject: Avionics cooling |
Hmm. An EFIS that is "outside the temperature limits . . . so it may not
be as accurate " - that's kind of scary.
TDT
40025
jaybrinkmeyer(at)yahoo.co Guest
Posted: Tue Aug 29, 2006 9:15 am Post subject: Avionics cooling |
I'll byte... What sort of "avionics" fan are you guys referring to and where
does one get one? I'm guessing Spruce (like everything else), but I haven't
looked.
Anyone know if Dynon is using mil-spec parts? How about gluing on a heat sink?
Seems like the Dynon engineering department might be interested in real world
feedback.
Does anyone have photos of where they are mounted said fans?
Jay
looking forward to bending fuse skins - not!
Posted: Tue Aug 29, 2006 9:51 am Post subject: Avionics cooling |
looked.
This is the one I got:
http://www.steinair.com/accessories.htm
You may not want to deal with Stein though....he's too nice for
most people. Try to find someone who'll treat you a little
worse.
Quote: | Anyone know if Dynon is using mil-spec parts? How about gluing on a heat sink?
feedback.
I mounted mine on one of the vertical ribs, forward of the subpanel.
Tim Olson - RV-10 N104CD - Flying 116 hours
Quote: | Thanks,
Jay
rvbuilder(at)sausen.net Guest
Posted: Tue Aug 29, 2006 9:54 am Post subject: Avionics cooling |
Yep Spruce. It's a multi port fan that you can hook SCAT tube to. Not
overly expensive either.
Michael Sausen
LIKE2LOOP(at)aol.com Guest
Posted: Tue Aug 29, 2006 1:24 pm Post subject: Avionics cooling |
In a message dated 8/29/2006 5:15:07 PM Eastern Standard Time, jaybrinkmeyer(at)yahoo.com writes:
Quote: | What sort of "avionics" fan are you guys referring to and where
looked.
Anyone know if Dynon is using mil-spec parts? |
Dont you all have a "large fan" out front already running every time the avionics are used? Why add more electrical components with failure potential, just run an air line off the vent to pass air over the back of the avionics??? Ambient air is all the same temp..... acutally a fan my just circulate hot air from under the panel???
DO NOT ARCHIVE
Steve
Stephen Blank #40499
766 SE River Lane
Port St. Lucie, FL 34983
772-475-5556 cell - evenings and weekends
Posted: Tue Aug 29, 2006 1:48 pm Post subject: Avionics cooling |
Moisture.
LIKE2LOOP(at)aol.com wrote:
Quote: | In a message dated 8/29/2006 5:15:07 PM Eastern Standard Time,
haven't
looked.
DO NOT ARCHIVE
Steve
766 SE River Lane
Posted: Tue Aug 29, 2006 4:09 pm Post subject: Avionics cooling |
Exactly, the last time I flew through rain I was really glad I didn't pipe
the air up into my avionics. I didn't get soaked, but there was no doubt
water was happy to press right in the ventilation scoops.
One other thought I had was to draw air from above the glare shield by. The
shield itself is hot, but the air just above seems pretty reasonable. I
also had a plan to set the switch up to reverse polarity and then I could
turn it into a defog like some guys have done. Some loss in efficiency
running the blades backwards, but it would be better than nothing.
Thoughts???
Marcus
40286 - flying, still testing
