Serious Front Axle Maintenance Issue on the RV-10
Goto page 1, 2  Next
Tim(at)MyRV10.com
PostPosted: Wed Aug 09, 2006 8:37 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
So that "small nosewheel shimmy" I've mentioned for the past couple
of weeks....
Tonight I found that the old posts someone previously made on this
subject REALLY need to be not only investigated fully, but I
completely believe that basically EVERY RV-10 will have this
problem if you do not plan ahead and do something about it before it
happens to you.
Check out this Front Axle and Fork wear write-up:
http://www.myrv10.com/N104CD/maintenance/20060809/index.html
If you read my write-up, you'll see that I previously even called
Van's after someone else had the problem, trying to proactively
"fix" the issue, even though I wasn't fully aware of exactly how
the problem manifested itself. What REALLY would be nice is if people
find things like this, post some pictures and an explanation.
A picture is worth 1000 words, and it makes it much easier to
understand. Had I known about this before, I would not be in this
position today. My front Fork is now worn with a groove, and my
temper is lit. Tomorrow I'll be calling again to find out if
there is already a "fix" that is finally publicly known...and then
I'll add it to the above page.
Additionally, this has prompted me to stay up a little extra tonight
and lay the groundwork for the "Maintenance Issue" section of the
RV-10 Tips page at:
http://www.myrv10.com/tips/index.html
Hopefully I can get some good input from others about things that
everyone really needs to watch for once they start flying. Lets
keep these planes in the air, and keep them safe.
henkjan(at)zme.nl
PostPosted: Wed Aug 09, 2006 10:51 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Hi Tim,
I did not like the construction of the front wheel bearing and made a
change even before putting my 10 on it's wheels because I had fear about
exactly what happened to your front wheel.
Van's provides two bushing made from thin wall stainless steel tubing
for mounting at the outside of the bearings only, this will not prevent
the bearing inner rings from rotating at the shaft, due to the heavy
seals my inner rings were rotating at the shaft, I didn't like that,
feared that the bushings would damage the fork, your experience proves
that.
Here's what I did, first I determined the distance between the bearing
inner rings, then I made an aliminium bushing on the lathe just a little
wider than the measured distance ( 0.1 to 0.2 mm) to give the bearings
just that little play that they need.
Then I made two aluminium bushings for the outside, dimensions just so
that the total of the two outside bushings, the two bearing inner rings
and the inside bushing are a little bit longer then the shaft, it all
clamps together during assembly.
I did not use the bushings supplied by Van's.
Now it's assembled it's a very rigid construction that allows the
bearings just to rotate at the point that they should as well as both
seals.
Need to say that the length of the bushing between the inner rings needs
to be measured for every wheel separately due to tolerances of the
wheels.
I can disassemble it again and post pictures if you want.
Henkjan van der Zouw
#40355, sorry, still building.........
-----Oorspronkelijk bericht-----
Van: owner-rv10-list-server(at)matronics.com
[mailto:owner-rv10-list-server(at)matronics.com] Namens Tim Olson
Verzonden: donderdag 10 augustus 2006 6:36
Aan: rv10-list(at)matronics.com
Onderwerp: Serious Front Axle Maintenance Issue on the RV-10
of weeks....
happens to you.
RV-10 Tips page at:
Tim(at)MyRV10.com
PostPosted: Thu Aug 10, 2006 3:40 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Thanks Henkjan, I only wish I had a mill handy again, but my friend
who's I used moved away. It sounds like you did exactly what needs
to be done, but it's a 1-off solution. I'd love to see photos
of yours or anyone's assemblies that they've fixed, but I don't
want to see you disassemble just for photos. Thanks for the
description of the fix though. External photos would be nice.
I'd love to see how big that piece is that fits next to the bearings.
Henkjan van der Zouw wrote:
Hi Tim,
that.
seals.
wheels.
of weeks....
happens to you.
RV-10 Tips page at:
rvbuilder(at)sausen.net
PostPosted: Thu Aug 10, 2006 6:19 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Man, someone didn't have their coffee yet when they designed that.
Before even reading your write-up or looking at the pictures the first
thing that popped into my head was a washer. I can't believe they put
in a SS bushing against an aluminum fork and didn't realize this would
happen. Duh.
Simplest and quickest fix is exactly what you are thinking Tim. Get a
large SS fender washer to take up the force from the bushing and spread
it out on the fork. Check the usual suspects such as McMaster-Carr or
worst case fabricate your own.
Someone was asleep at the wheel on this one.
Michael Sausen
RV-10 #352 Buildus Interuptus due to moving
Vern(at)teclabsinc.com
PostPosted: Thu Aug 10, 2006 7:04 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Hi Tim,
On my old Cessna 150 they used caps (in place of the bushing U-1023)
that fits over the end of the shaft (U-1009). When the shaft is bolted
to the fork the cap is held in place by the compression between the bolt
head and the end of the shaft. I never really understood the why it was
designed that way until looking at your pictures.
If the shaft size is the same you may be able to pick up some used caps
for a Cessna and use these to replace the bushings.
Vern (#40324 wings) do not archive
Ray.R.Doerr(at)sprint.com
PostPosted: Thu Aug 10, 2006 7:28 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
I didn't have much luck with Van's on this issue as well. My A
& P caught this issue before I had the plane inspected and what we came
up with is to shave .040 off the aluminum axle itself so the wheel won't
slide side to side. Once I did this the wheel was solidly in the middle
in the axle with enough force on the bearings so as to create a slight
drag on the tire when trying to turn it by hand.
I will check on mine tonight and report back. I currently have
106 hours on my plane.
Thank You
Ray Doerr
40250
N519RV (Flying)
Tim(at)MyRV10.com
PostPosted: Thu Aug 10, 2006 7:43 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
I have some new info on the Axle issue. I'll post the text here,
but I updated the web page for better readability.
Refer to page 46-06 on your plans for visual information
I both figured out an idea, and just got off the phone with Gus at
Van's. Yes, they are aware of the issue. Apparently they did change
the U-1023 spacers that are delivered with the kits and now instead of
thin stainless steel, they're thick aluminum spacers, that should spin
less easily, especially stuck against the similar aluminum, as it might
tend to gall and stick. He didn't know why they didn't make it an S.B.
and send out new parts. So, this is DEFINITELY something to address for
anyone who hasn't yet, and these parts should be available free. This
isn't to say that the new fix is ideal, but certainly better than what I
had to fly with for 100+ hours.
The NOSE FORK ASSY part is somewhere around $160, for those who are
interested. I may end up doing that, depending on how paranoid I
am....which remains to be seen.
I am getting the new spacers via UPS ground, instead of overnight,
because I also have one other thing that I'd like to try and accomplish.
Personally, I think I know what needs to be done to protect those
forks. Today at fastenal I found 3/8" ID x 1.5" OD stainless fender
washers and they're .050" thick. A very similar Aviation hardware
washer would be the AN970-6, which are only 12 cents at Van's and are
1-5/8" diameter and .063 thick. The idea is that if that U-1009 axle
is cut down in length by the same thickness as 2 of those washer, you
could then install a large-area flat washer against the fork, and that
would prevent EVER having that fork wear. You never want to
unnecessarily wear an expensive part. So, on my order is a few
AN970-6's, -7's, and a new U-1009 axle. The axle was about $15, and I
ordered it so that I could allow these parts to ship UPS ground, and
still feel good about chopping up my old U-1009 and shortening it at a
local machine shop so I can put these washers in for the weekend. If
the new spacers work fine with my shortened axle and washers, then I
will just leave it that way permanently. Small price to pay to fix the
issue fast....less than an hours' flight time. The bigger problem is
until I either get over it, or buy a new fork assy, I'm going to have
that nagging thought of the fork damage. There's still about .290-.300
thickness to that fork, which should be good, especially if you hold
that nosewheel off well on landing.
More photos to come as things come together...
If you read my write-up, you'll see that I previously even called Van's
after someone else had the problem, trying to proactively "fix" the
issue, even though I wasn't fully aware of exactly how the problem
manifested itself. What REALLY would be nice is if people find things
position today. My front Fork is now worn with a groove, and my temper
is lit. Tomorrow I'll be calling again to find out if there is already
a "fix" that is finally publicly known...and then I'll add it to the
above page.
Additionally, this has prompted me to stay up a little extra tonight and
lay the groundwork for the "Maintenance Issue" section of the RV-10 Tips
page at:
everyone really needs to watch for once they start flying. Lets keep
jack.lockamy(at)navy.mil
PostPosted: Thu Aug 10, 2006 7:54 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Why not just drill a single hole in each side of the fork and into the spacers just forward or aft of the axle bolt? Counter sink the hole(s) on the outside of the fork (both sides), tap the hole in the spacer for a #8 screw, insert a #8 countersunk/flush screw in each hole and you're done! No way that spacer is gonna rotate...
I did this on my RV-7A before this was ever even mentioned as I could see that the spacer could easily rotate and cause the fork to be 'grooved'. So far the 'preventive measure' taken above has proved to work, took less than 10 minutes and I didn't even need a lathe...
Jack Lockamy
N174JL RV-7A 210 hrs
Camarillo, CA
www.jacklockamy.com
mike(at)cleavelandtool.co
PostPosted: Thu Aug 10, 2006 8:03 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Back in the 80's and early 90's before the full swivel tail wheel all the
tail dragger RVs had a similar problem with the tail wheel. We made a kit
to fix it using the same idea as Henkjan. I don't know if it would be
possible to make a kit for this if the wheels vary in thickness, but if
someone finds a solution I would be happy to make a kit of the parts.
Mike Lauritsen
Cleaveland Aircraft Tool
2225 First St.
Boone, Iowa 50036
515-432-6794
mike(at)cleavelandtool.com
Tim(at)MyRV10.com
PostPosted: Thu Aug 10, 2006 8:12 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Ray,
You may still want to protect that fork.
I've got you beat on hours, but only by 1 hour....107.4.
Man, you're flying the pi$$ out of that thing! Good job!
Tim(at)MyRV10.com
PostPosted: Thu Aug 10, 2006 8:19 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Yep, in my write-up, that's actually my proposed method of fixing
the rotation. I think this stuff should be done during the initial
build, and nobody even have a problem to talk about...especially
now that they'll have a thicker spacer, it would be easy to do.
Jack Lockamy
Camarillo, CA
www.jacklockamy.com
bhughes(at)qnsi.net
PostPosted: Thu Aug 10, 2006 8:54 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Mike,
This is one problem Van's should fix and very soon. This is be a Service
Bulletin.
Bobby
(40116)
acs(at)acspropeller.com.a
PostPosted: Thu Aug 10, 2006 2:28 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Tim, fantastic idea. I'm glad someone like yourself is taking the time to
help the rest of us out with these information issues.
Following is an extract from an email sent to me a few days ago,
"returned the nosewheel to Matco to have it replaced with WHLNW511.25 which
is correct for the valve stem on the tube and avoids the clearance problem
with the supplies WHLNW501.25."
As I'm no where near my plans at the moment I don't know if it is relevant
to your findings, is an issue or can even help.
I'd also suggest adding to your maint issues, the clearance issue with the
elevator trim motor and as someone has mentioned in the last few days the
co-pilot left rudder pedal clearance on the tunnel wall. Both could pose
safety issues down the track.
John 40315
wayne.e(at)grandecom.net
PostPosted: Thu Aug 10, 2006 4:37 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
I'm currently building in Justin, TX in George0 Orndorff's hangar, he's the one that makes the RV building videos and is also a0 Van's tech center, and I was talking to him about this problem, wondering if I0 needed to take some type of action on mine. His response to me on this issue was0 that this was a quite common occurrence on the RV's. He said the reason he0 believes it happens is that when the builder tightens down the bolt holding on0 the bushing and tire that they tighten it down too much. He said I should just0 tighten it down just until it's snug. Then after flying it for 5 or 10 hours0 check it and retighten it. Do this over the first 20 or 30 hours.
I have a friend who is an A&P and also a DAR0 and I called him and ask him the same question. He agreed with George. He said0 to tighten the bolt down until a little grease comes out of the bearing and then0 back it off a little and then keep an eye on it for awhile.
This may not be the case on Tim's plane though?0
For what ever it's worth.
Wayne Edgerton #40336
PostPosted: Thu Aug 10, 2006 5:39 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
They are basically correct. However I disagree with their solution. When you have two metals of this dissimilar of a hardness rubbing together with such a small surface area something is going to give eventually. You need to spread that across a more substantial area. Even my cheap wheelbarrow has this provision.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Thursday, August 10, 2006 7:36 PM
Subject: Re: Serious Front Axle Maintenance Issue on the RV-10
I'm currently building in Justin, TX in George Orndorff's hangar, he's the one that makes the RV building videos and is also a Van's tech center, and I was talking to him about this problem, wondering if I needed to take some type of action on mine. His response to me on this issue was that this was a quite common occurrence on the RV's. He said the reason he believes it happens is that when the builder tightens down the bolt holding on the bushing and tire that they tighten it down too much. He said I should just tighten it down just until it's snug. Then after flying it for 5 or 10 hours check it and retighten it. Do this over the first 20 or 30 hours.
I have a friend who is an A&P and also a DAR and I called him and ask him the same question. He agreed with George. He said to tighten the bolt down until a little grease comes out of the bearing and then back it off a little and then keep an eye on it for awhile.
toaster73(at)earthlink.ne
PostPosted: Thu Aug 10, 2006 6:22 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Here is a link where one can learn a lot about0 tapered roller bearings, and the proper design intent. Granted our nosewheels0 won't see as many miles or speeds as a BMW motorcyle, but I found the article0 very informative. I don't have the nosewheel yet so I don't know exactly how it0 all goes together , but from Tim's pictures it looks pretty cheesy.
-Chris Lucas
#40072
R75/5
PostPosted: Thu Aug 10, 2006 6:23 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Oops forgot the link
http://w6rec.com/duane/bmw/wheel_bearing/index.htm
Tim(at)MyRV10.com
PostPosted: Thu Aug 10, 2006 8:41 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Wayne, for what it's worth, I really don't think this will work
that way on the RV-10. I may be wrong, but I think you really need
to tighten that thing well on this plane or you'll REALLY have problems.
I'm betting that the assembly those guys are familiar with isn't the
same thing as what we have. If you have any looseness, you're going
to really screw up your axle. I just updated that page....scroll
to the bottom to read tonights update. I got a little long winded again
(surprise surprise), but I explained the axle and rotation and other
things in a bit of depth. For you -10 builders, that page is really
worth understanding, just so you can ponder it and know what's going
on there....even if you come to some other conclusion. (if you do,
let me know...I'd love to hear it, or hear exactly what the mechanics
are that George thinks would be better if it were looser)
I'll post the text of tonights update here again, but you would be
much better served to just read it on the page, and see the latest
photos. This is just for the archive's sake.
Here's the link again.
Today I stopped by a machine shop and had them take off about .115" off
my axle, to accomodate 2 AN970-6 washers on the outer edge. Yes, they
are .063 each, so .126" would have been the standard, but I wanted the
axle to be even just a little more snug than before, because any flexing
inward will bring that valve cap closer to the fork. As a side note,
this from John D. today...a note someone sent him:
which is correct for the valve stem on the tube and avoids the clearance
problem with the supplies WHLNW501.25."
In other words, Van's is sending out the wrong wheel for the application
on this plane...because they use this wheel for the RV-7's and such, and
didn't want to have to stock 2 parts. So we get to receive the one that
isn't made for the application, and therefore unless you swap wheels,
you're going to have minimal valve stem clearance.....pretty nice, huh?
<not>
Anyway, I had the axle cut shorter at a machine shop, and then I just
had to guesstimate how much to take off the 2 spacers. Knowing they had
worn into a taper on the inside, to fit against the bearing, I had them
only cut down by .085" total. I did .035" on one side, and .050" on the
other. That way I could have a slightly longer sleeve on the left side,
so my valve stem had just that little extra clearance from the fork.
This brought forth a small problem... Tonight when I assembled it as in
the first photo below, it looked great. VERY much better than original.
Then, when I put the whole wheel together, I found that the spacers
had worn probably at least .120" because there was tons of slop in the
spacers yet, even though they now had a nice flat surface to sit
between, and had been cut less than the axle, and the washers were in
there to fill in some space. The spacers just spun. So, I decided
since I already ordered another axle, I'd take my bandsaw and VERY
carefully trim off some more axle, and just use one more washer on the
left side. That should keep that valve stem even FURTHER away. If I
was right, I could get it so there would be plenty of pressure on the
bearings and spacers to hold them in place so they don't spin. Sure
enough, it worked just great. I could now torque that bolt down tight
and keep the spacers from spinning, and the bearing too. Just to be
totally sure they never spun again, I drilled a couple of holes in the
stainless spacers, and remounted it all. Then I made a pilot hole in
the aluminum axle shaft, and took it all apart and tapped it for an 8-32
screw on each spacer. Then I cleaned it up, regreased, and put it all
together. Now it is very solid, and should never wear the fork
again....I just am left with a crappy fork...so I'll probably just get a
new one. Once my new spacers and axle come in, I may tear it all apart
and use those pieces, but I'll still probably cut the axle and spacers
down and use the washers on the outer ends. It will prevent your forks
from being the sacrificial component. The bearing, for future
reference, is a Timken LM-6700-LA (I think that's right, but I'll
re-check tomorrow)
A note about tightening the axle nut... Tonight on the RV-10 list,
someone said that George Orndorff (A Van's tech center place), says that
the bolt should only be snugged, and then rechecked often in the first
few hours. I don't personally believe this is true on the RV-10, but
perhaps it is on the other models. Here's why. I studied this long
and hard, and now I fully understand why this is such a huge freaking
issue. It didn't make sense at first, having worked on dozens and
dozens of automotive bearings in the past. You see, on automotive apps,
the bearings are pressed in on the backside, and a nut and washer holds
the bearing tight. But it pushes against a different area of the
bearing. And the grease seal is usually a seal that is pressed into the
hub, with a seal around the shaft on the ID of the seal. This is NOT
how these bearings are on this application. On THIS application, you
are expecting that the sleeves, the axle, the bolt, AND the inner race
area of the bearing do not ever rotate. The problem is, if these
bearings were a tight knurled, or press fit onto that axle shaft, it
might be easy to keep them from rotating by just not letting the shaft
spin. But, what happens here is that the grease seal is a large seal
that the wheel spins around....so the seal is on the OD of the bearing
in this case. That's why my stinking seals were so torn when the wheel
wobbled. The kicker to the problem is, if you don't have the spacers
very tight against the bearing, there's not enough force to keep the
bearing from turning on the shaft. If the bearing spins on the axle
shaft, then it's becoming USELESS as a bearing. At that point, you're
using the aluminum axle as the bushing, and the wheel is rolling by
spinning the hard steel bearing race against your soft aluminum axle
shaft.....instead of turning the roller bearings inside of the wheel's
outer race. The seal itself has a lot of drag against the wheel as it
spins, and this drag will make it so that the wheel tries REALLY hard to
make the bearing spin. As it turns out, if you don't have tight
spacers, it's really easy to get that bearing spinning. And once the
bearing is spinning, the spacers stuffed right up against it will spin
too. And once they start spinning, they'll spin against the fork. If
you have the stainless ones like me, they'll ABSOLUTELY then start
carving into your forks. If you have the new and improved thick
aluminum ones (that I can't comment firmly on because I haven't seen
them), then they would have more surface area against both the bearing
and the fork....so on one hand the bearing will try to turn it harder,
but the fork will prevent it harder as well. To me, this is STILL
going to be a less than ideal situation until you PREVENT the spacers
from turning, and you PROTECT the forks from being worn if they do turn.
The lock screws I put in should keep the spacers still. The washers
will protect the forks. The one further improvement that would be
simple would be to drill a tiny hole in the fork on one side, that
drills into the aluminum axle, and then tap for a small hex head
internal setscrew lock, so that you could pin the axle from rotating at
all too. Beyond that, the only real improvement I could think of is if
you could find a way to either press-fit, or hold that inner bearing
from turning on the axle. Perhaps knurling it, epoxy, a small keyway
and shear key, or something like that would be the ticket. If you've
done all of the other steps, and have tight spacers, you probably
wouldn't have any huge issues from that point.
The worst thing about it is that no matter what you do, you really don't
have independent control over how tight the bearings are
seated...separate from how tight the axle bolts are and how long the
spacers are. Just to let you know how this all ends up the way I have
it tonight, the wheel will not continue rolling if you spin it by hand.
I don't think it's too tight from a bearing perspective, but the
grease seals against the wheel hub provide a lot of drag, so they don't
let the wheel spin real freely.
A couple other tips, while I'm at it. By the time you get to 25 hours
on your plane, re-check that large nut that holds the fork on. Mine
needed to be tightened almost one full flat to the next castle stop, to
retorque it after it took it's set. I think the spec is about 24lbs.
pull of breakout force to rotate the nose at an angle.
The second tip that I can't yet verify is fairing balance. To prevent
shimmy, I've heard that a good idea is to balance your fairing. Since I
had a little lead shot around, and I wanted this all to be perfect now,
tonight I weighed out a little lead and taped it to the nose of the
nosewheel fairing. I got it so that I could hold it where it mounts, in
the centers of those 4 screw areas, and get it to be about neutrally
balanced. Then I just took a little shot away, poured the rest into
the nose of the fairing, and mixed a couple of squirts of epoxy. I
poured the epoxy into the nose over the shot, put down one layer of
cloth, and then a little more epoxy. By tomorrow that stuff won't be
going anywhere, and I already re-checked the balance and it's now much
less tail heavy, so maybe that will improve things too.
Tim Olson - RV-10 N104CD - 107 hours Flying
ddddsp1(at)juno.com
PostPosted: Thu Aug 10, 2006 10:03 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Tim,
Are you planning to drill thru the fork into the axle and TAP it with a contersunk screw to keep the axle from turning like you did to the spacer? I am thinking it would be easy to do and would eliminate the axle from turning even if the wheel got loose.
Dean
Getting engine today.
________________________________________________________________________
Try Juno Platinum for Free! Then, only $9.95/month!
Visit http://www.juno.com/value to sign up today!
Tim(at)MyRV10.com
PostPosted: Fri Aug 11, 2006 3:42 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 Reply with quote
Yeah, but not until I get all the new parts and see them.
That's one hole I'll "drill once".
ddddsp1(at)juno.com wrote:
Tim,
Dean
Goto page 1, 2  Next
Page 1 of 2
