Manifold pressure hole
ddddsp1(at)juno.com
PostPosted: Wed Aug 23, 2006 8:56 pm    Post subject: Manifold pressure hole Reply with quote
I went to drill the hole in the firewall for the manifold pressure fitting............it says to drill a 3/8" hole. The fitting does NOT go through the hole because it is too small. What am I not doing right? It appears to me the hole needs to be drilled to 7/16" for the fitting to go through. Is it a typo in the manual?
DEAN
40449
________________________________________________________________________
Visit http://www.juno.com/value to sign up today!
