Model 3 with a 503 "Do-able"?
manliker(at)uiuc.edu
PostPosted: Wed Aug 23, 2006 7:13 am    Post subject: Model 3 with a 503 "Do-able"? Reply with quote
Anyone with a Model 3 (or similar) flying with a Rotax 503 engine installation? I have a friend who just bought a Model 3 w/o engine, and he’s “kicking around” installing a 503. Does anyone have experience with this airframe and engine combination? Is it underpowered with two up?
jose_m_toro(at)yahoo.com
PostPosted: Wed Aug 23, 2006 8:54 am    Post subject: Model 3 with a 503 "Do-able"? Reply with quote
Mark:
Skystar once offered the Kitfox 2 Lite. It is my
understanding that it was a Model IV that was kept
light during construction. Model III fuselage is
lighter than Model IV. It should be possible!
However, I don't know any case. It will certainly
have less climb that a 582 powered KF III. However, I
will not be surprised if cruising is similar.
Jose
Rotax 503 engine
he's "kicking around" installing a 503. Does anyone
have experience
up?
RichWill
PostPosted: Wed Aug 23, 2006 4:00 pm    Post subject: Re: Model 3 with a 503 Reply with quote
I wouldn't do it! Unless you are a 100lb pilot, will never take up another passenger, won't fly in hot humid weather... you'd be pushing the envelope..
Don't get me wrong.. the 503 is a great engine.. but a normal Model 3 with fuel and pilot is going to be a load for a 503..
my two cents
Rich
7suds(at)Chartermi.net
PostPosted: Wed Aug 23, 2006 4:41 pm    Post subject: Model 3 with a 503 "Do-able"? Reply with quote
Mark,
I built and flew a Model IV XL Series with a 503DCDI with a 3 blade ground adjust GSC for 5 years. The kit was sold by Skystar with that engine option. My empty weight was around 530 pounds, and useful load was 420. I was pleased with the performance for a 52hp bird, it would get off the ground faster than the 150 I was previously flying, about 500' on grass and 200 on pavement (or less with a head wind). I have flown all my children in it but not enough gross for me and my wife, I am 6' 2" 220 pounds. I flew the plane into Oshkosh Airventure 3 times and I was loaded to the max when I did it. It had two 6 gal wing tanks and a custom 10 gal aluminum header tank behind the panel. I would get 70 MPH cruise at 5900 RPM climb was at 55 MPH (at) 6400 RPM and I would get about 700' / min with me in it, had wheel pants but no strut fairings. Was pleased with the engines reliability, when it would get very hot, (like airventure time) I would have to make a jet change to maximize engine performance. Was a blast to fly, but then I think they all are. Is it the best engine for the 3, I don't know, If the price is right and the numbers fit it might for now. I am building a 5 with a 912, I am sure I will like it better but I have nothing but fond memories of my 4 with the 503 in it.
Lloyd
 Filesize:  37.55 KB
 Viewed:  588 Time(s)
 Filesize:  37.64 KB
 Viewed:  573 Time(s)
dave(at)cfisher.com
PostPosted: Wed Aug 23, 2006 5:57 pm    Post subject: Model 3 with a 503 "Do-able"? Reply with quote
Good report on the 503.
I just replaced a 503 single carb in a Kitfox 1 this week.
I broke the engine in today and test flew it for 30 mins. Will retorque heads tomorrow.
This one weighs about 410 lbs and performs well solo and dual with 2 (at) 200 each will fly fine but not a hot rod.
A model three i think has a 1050 gross and I think the 503 would make is underpowered but would fly. The biggest problem is that you would miss all the fun you could have with a 582 giving near 50% more HP and will give you an excellent performer both solo and dual.
What would be reason to choose a 503 over a 582 ?
Does he need engine mount as well? I did email a guy that had a complete FWF package for a Kitfox 582 for sale but I do not have his info anymore. I think i got it from Green sky aviation but I am not 100% sure.
Dave
