Converting fixed pitch to constant speed
pilotdds(at)aol.com
PostPosted: Wed Sep 06, 2006 6:09 am    Post subject: Converting fixed pitch to constant speed Reply with quote
Could any of you folks knowledgable about the conversion advise me if external oil lines are necesary when making this conversion.My understanding is that the outside plug must be removed a 1/8 plug must be placed inside the crankshaft and external oil lines are necesary for rear mounte governors but not front mounted type. Is this correct? 728dd-flying
coop85(at)bellsouth.net
PostPosted: Wed Sep 06, 2006 4:20 pm    Post subject: Converting fixed pitch to constant speed Reply with quote
I can’t help with the 1/8 plug, but you will need to remove the outside plug and there are no oil lines on a front mounted governor.
Marcus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds(at)aol.com
Sent: Wednesday, September 06, 2006 10:09 AM
Subject: Converting fixed pitch to constant speed
pilotdds(at)aol.com
PostPosted: Thu Sep 07, 2006 7:44 am    Post subject: Converting fixed pitch to constant speed Reply with quote
thanks for the info
