[SPAM] Air Conditioner
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
czech6(at)kellin.net
PostPosted: Mon Aug 21, 2006 2:43 pm    Post subject: [SPAM] Air Conditioner Reply with quote
It turned into "Big Business". He has a manager handling the sales and tech
support. So as is the case with any "Big Business", red tape and lots of
middle men.
Bill
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
Ernie
PostPosted: Mon Aug 21, 2006 3:38 pm    Post subject: [SPAM] Air Conditioner Reply with quote
Did you get more details??? Did I divulge trade secrets? Smile
Ernie
Hey, I may fly out to Colorado Springs in Oct for the Bonanza
Convention, maybe we could hook up then.
Ernie
middle men.
Bill
RAMPEYBOY(at)aol.com
PostPosted: Mon Aug 21, 2006 4:02 pm    Post subject: [SPAM] Air Conditioner Reply with quote
I mentioned the same possibility of using this window unit in my Mustang II experimental. I'm no electrical engineer so don't quote me on this as I probably have it all backwards, but something about the amps that unit pulls is at the AC 110volt setting. It would supposedly pull more like 60 amps DC? Your L-29's may easily handle this, but that's pushing most DC alternators...
Boyce
Ernie
PostPosted: Mon Aug 21, 2006 4:22 pm    Post subject: [SPAM] Air Conditioner Reply with quote
Not at all. You need to just use OHM's law and convert to power, 4.5
amps (at) 110v = 495 watts, P=E x I ...conversly I = P/E so 495 watts
divided by 24v = 20 amps at 24V. For startup current just double that
value and that ups the startup current requirement to 40 amps, add 10%
for Inverter inefficiency and you're in the neighborhood of 50 amps
for startup, and about 25 amps while running. The inverter I saw for
$100 was rated at 900 watts continuous with 1800 watts peak, more than
enough for this application. I've never seen these tiny window units
before, thats why I never considered using window units, but the
weight and current draw of these little babies makes them viable.
Also remember that the alternator need not be able to keep up with the
momentary startup current requirements, since the battery will act as
you current storage tank, the alternator just replenishes the current
during continuous use. Even a 30 amp alternator would be able to
supply 5 amps of charging current during continuous AC use, but I
wouldnt recommend doing this with anything under a 50 amp alternator.
Ernie
alternators...
Boyce
- The L29-List Email Forum -
to browse
Archive Search & Download, 7-Day Browse, Chat, FAQ,
much more:
- NEW MATRONICS WEB FORUMS -
the Web Forums!
http://forums.matronics.com
- NEW MATRONICS LIST WIKI -
Wiki!
http://wiki.matronics.com
- List Contribution Web Site -
PostPosted: Mon Aug 21, 2006 5:04 pm    Post subject: [SPAM] Air Conditioner Reply with quote
Ernie, I recently bought one of these units when my heat pump at home failed. If memory serves the box advertised it weighed 40 pounds. It may come in at less than that once you strip it of it's current chassis, and reconfigure to fit into the L-29. All food for thought huh?
PostPosted: Mon Aug 21, 2006 5:21 pm    Post subject: [SPAM] Air Conditioner Reply with quote
Reviewing some of the conversations we had on the Mustang site on this topic, another consideration that was brought up a couple times is possible interference between an inverter and the avionics....On a positive note, it could be run on the ground from a normal 110 plug in. Get the plane cooled down without draining the battery!
Bcolombo(at)twcny.rr.com
PostPosted: Mon Aug 21, 2006 5:45 pm    Post subject: [SPAM] Air Conditioner Reply with quote
I think the inverter numbers are a bit off. here is the formula for power
invertes. This is for a 24v to 110/120 inverter
Here's the formula for all power inverter: Amps (needed) x (volts)110 V AC =
wattage of inverter needed
50amps needed for start X 110v =5500 watt inverter. I have a 1000 watt
inverter and it does not run much let alone a small AC unit. The inverter
needs a lot of air(on the ground is the only time this would be an issue) or
it will overheat and trip fast.
sure would be nice to have it though. I would also go as far as to put a
small boat type halon system in the nose if that was the place I vould run
have the compressor. Again big heat producer and they are not ment for
closed spaces. just my 2 cents.
schwartzcompany(at)worldn
PostPosted: Mon Aug 21, 2006 6:22 pm    Post subject: [SPAM] Air Conditioner Reply with quote
what are the brand names of these little window units??
Robert E. Schwartz
This information is intended for the use of individual named above. If you
are not the intended recipient, you are hereby notified that any disclosure,
copying, distribution, or the taking of any action in reliance on the
content of this information is strictly prohibited.
PostPosted: Mon Aug 21, 2006 6:29 pm    Post subject: [SPAM] Air Conditioner Reply with quote
Lets plan on it.
SD737(at)aol.com
PostPosted: Mon Aug 21, 2006 8:02 pm    Post subject: [SPAM] Air Conditioner Reply with quote
Hi Ernie,
Sorry about the delay getting back to you. The full time flying job is the one that pays the bills and I've been busy with United. Then got side tracked with getting checked out in a L-39, which solves the AC problem as long as I don't go back and fly my L-29. LOL>
I'll email you directly.
Thanks.
SD737(at)aol.com
PostPosted: Mon Aug 21, 2006 8:04 pm    Post subject: [SPAM] Air Conditioner Reply with quote
Sounds like we could just cut open the canopy and silicone in a home window mount AC unit and strap it down. That should work for until you get airborne... LOL
PostPosted: Mon Aug 21, 2006 8:11 pm    Post subject: [SPAM] Air Conditioner Reply with quote
scott, e-mail me directly with info as well please. bcolombo(at)twcny.rr.com (bcolombo(at)twcny.rr.com), Still need a tach/gen and tach if you know of anyone who might have a used one.
brian
SD737(at)aol.com
PostPosted: Mon Aug 21, 2006 8:16 pm    Post subject: [SPAM] Air Conditioner Reply with quote
Hi Bill,
Speaking of Red Tape, you coming to Reno Air Races. I most likely will be doing an engine change on my L-29 and any extra bureaucracy "help" would be welcomed.
colyergreg(at)aol.com
PostPosted: Mon Aug 21, 2006 8:37 pm    Post subject: [SPAM] Air Conditioner Reply with quote
I had a nose gear problem in my L-29 this weekend. A problem all of us can have due to a design flaw. Simple fix though. Will type up what happened and post it here and the CJAA web site tomorrow morning. (with photos) At work now and not enough time to type it up.....All ended up well though when I hit the mains down hard and got the nose wheel to lock before setting it down....
SD737(at)aol.com
PostPosted: Mon Aug 21, 2006 8:40 pm    Post subject: [SPAM] Air Conditioner Reply with quote
I heard it was pilot error! Or several errors.. LOL
PostPosted: Tue Aug 22, 2006 2:20 am    Post subject: [SPAM] Air Conditioner Reply with quote
The AC unit I bought from Walmart is a Goldstar. I gave it a hard break in, running it wide open for 4 days until I made a decision which heat pump to install. Never missed a beat. I paid $86 I believe.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
