Electric Flaps option
Goto page 1, 2  Next
flyrv6(at)bryantechnology
PostPosted: Fri Aug 18, 2006 8:21 am    Post subject: Electric Flaps option Reply with quote
Ok listers, here is my questions.
I have been building my -6 for 16 years now but finalizing the assembly at the airport now. I am pretty close but finding the need to change/ update some things. The tailwheel which I previously posted about needed to be changed to full swivel. It did take me some time to mess with this, but I will be happier.
The flaps is the next question. I was pretty set on having manual flaps, but beings I put a quadrant in I would like to eventually after flying have a arm rest in the center. Unfortunately the manual flaps make this difficult. After flying with Mike Seager using the electric flaps, I figured it wasn't so bad. So, here's my questions:
Is changing the flaps to electric easier using the existing weldment?
What would be the disadvantages to using it?
How does the replacement weldment mount in the aircraft?
I understand the RV-10 has an electric switch that is position controlled, Could I use this? In the trainer we just held the switch down for 4 seconds to get half flaps. This has always been my complaint about electric flaps. I don't want to hold a switch for a count.  Sounds like the RV-10 has a fix for this.
How big a job am I looking at to change this over? I am trying to figure out weather to go ahead and do it now or get flying first.  Don't want too many more delays.
Thanks as always for any input
Tim Bryan
RV-6
N616TB
recapen(at)earthlink.net
PostPosted: Fri Aug 18, 2006 9:18 am    Post subject: Electric Flaps option Reply with quote
Tim,
The weldment is a different one for electric.  It will get in the way of a future armrest too.
I'm relocating the 'electric' actuator arm to the right side - next to the flap arm and will put the motor over there too (been done before - check the archives) to make room for my arm rest / entry foot step.
Van's has a switch which allows for nice operation...down once for 10, again for 20 again for full, up once to retract.
Ralph
RV6AQB N822AR (at) N06 Firewall foreward - then wings/flaps......
[quote]--
PostPosted: Fri Aug 18, 2006 9:31 am    Post subject: Electric Flaps option Reply with quote
Hi Ralph,
Thanks for the comments. I am not sure how the electric gets in the way for an armrest. I thought only the flap handle (manual) needing to move up or down would be in the way. What am I missing? Also Van's catalog shows two different conversion kits. One which uses the existing weldment and another kit with the original weldment used for electric. I am not sure which way would be the best or how the other type mounts.
I love that switch idea, hope I could use that.
--> RV-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)>
Ralph
sbuc(at)hiwaay.net
PostPosted: Fri Aug 18, 2006 9:35 am    Post subject: Electric Flaps option Reply with quote
Tim Bryan wrote:
<snip>
for this.
many more delays.
Here is a link to notes on the manual to electric flap conversion in my
RV-6:
http://thervjournal.com/fuse7.html#flaps
If you can weld or have access to someone that can, the manual torque
tube can be readily modified. Otherwise, it would be easier to buy the
arm from Vans.
In my opinion the conversion is one of the best mods you can make to
your RV-6 (full-swivel tailwheel was a good one, too). Total shop time
for the mode was about 18 hrs. I find it easier to make a quick glance
over the shoulder to check flap deployment rather than counting.
Electric flap operation quickly becomes intuitive as you sense the
impact of flaps on the airplane attitude/speed and the whole "counting"
thing becomes moot. I suggest you make the mod now while you are in
building mode and so you can get accustomed to electric flaps from the
get-go.
Go for it!
Sam Buchanan
jeffpoint
PostPosted: Fri Aug 18, 2006 10:02 am    Post subject: Electric Flaps option Reply with quote
Sam did this a few years ago and write it up on his website:
http://home.hiwaay.net/~sbuc/journal/fuse7.html#flaps
The device used in the 10 to position the flaps is available from Vans
for all other RVs as well:
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1155923952-384-594&browse=electrical&product=fps
Jeff Point
RV-6 flying
RV-8 preview plans in hand...
Milwaukee
Jeff Point
RV-6
Milwaukee WI
ronlee(at)pcisys.net
Can't answer you questions but as long as it is possible to retrofit
this change just go fly and wait until winter to make the change.
Ron Lee
PostPosted: Fri Aug 18, 2006 10:21 am    Post subject: Electric Flaps option Reply with quote
Sam,
Pictures are worth a lot. Thanks for directing me there. The one thing I notice is the flap tube is now mounted on the back side the side mounts. Does this require any reworking of the mount area? Also is the modified weldment the same thing as the weldment if purchased from Vans?
Thanks for the help.
[i]----
PostPosted: Fri Aug 18, 2006 10:58 am    Post subject: Electric Flaps option Reply with quote
Tim,
You should be able to use the switch if you're using electric flaps - there's a part that attaches to the flap motor.
I don't know about using a manula actuator for electric operation...I do remember that I bought my QB with elec flaps and there were a few parts that stick out forward into the 'armrest' area. I'll try to remember my elec flap instructions this weekend and zap them to you so you can see what you're getting into.
I agree with Sam do it now - I would also suggest looking at how it operates to determine what impact it will have on your armrest. IMHO it's easier to get an elec flap weldment than search out a welder - although I'll have to do that for my mod regardless.
Ralph
sbuc(at)hiwaay.net
PostPosted: Fri Aug 18, 2006 11:42 am    Post subject: Electric Flaps option Reply with quote
Tim Bryan wrote:
Sam,
from Vans?
Tim, it's been several years since I did the mod so some of the details
have escaped me. I don't recall anything more than just moving the tube
blocks to the backside of the bulkhead. Seems I used the same bolt holes.
The modified torque tube will end up being the same as a new electric
tube. The entire process is well documented in the instructions that
come with the kit and the welding required is simple, just a matter of
welding on new ends for the rod end bearings after you shorten the arms.
My hangar-mate has electric flaps in his RV-6A and also has an armrest.
Seems to me the only reason some might move the motor to the side of the
plane is so the storage compartment in the armrest could be bigger. I
considered putting the motor on the side but decided it wasn't worth the
effort of modding the mod. Smile
Sam Buchanan
PostPosted: Fri Aug 18, 2006 12:27 pm    Post subject: Electric Flaps option Reply with quote
Hi Sam,
I agree with you after looking at your pictures it appears there is room for an armrest. Mostly it isn't for storage for my purpose but a place to rest my arm while using the quadrant. Now is a good time for me besides the extra time since the flaps are currently off, and the handle comes easily out.
Thanks for your help
[i]----
FLYaDIVE(at)aol.com
PostPosted: Fri Aug 18, 2006 5:12 pm    Post subject: Electric Flaps option Reply with quote
In a message dated 8/18/06 12:25:04 PM Eastern Daylight Time,
flyrv6(at)bryantechnology.com writes:
Tim:
The simple answer is DO NOT INSTAL A CENTER ARM REST!
1 - There is not enough room.
2 - It will be in the way when you Need to work under the panel ... And you
WILL need to work under the panel.
3 - Unless you and your copilot are 100 Lbs each There is not enough room.
Yo already will be bumping elbows and maybe even butts.
4 - The RV-6 does not need an arm rest, your legs are your arm rests.
5 - I have always preferred MANUAL FLAPS but both RV-6's I fly have electric
flaps. They are acceptable. But, I still prefer Manual.
Why? I lost all electric and could not deploy the flaps.
When was the last time you practiced a ZERO FLAP landing?
Did you hit the numbers?
How long did it take you to stop?
I read the spec sheet too and seen what they say about how SLOW the stall
speed is. I was also taught by a CFII/ATP that has 2000 Hours in RV-6's. His
answer was: "You want to fly 5 Kts over Stall on approach? Not with Me or My
Plane! 80 Kts over the fence!"
The RV-6 is not the most stable of planes at slow speeds and the flaps do
make it MUCH better on the final approach.
And before you guys light your flame throwers. I have about 250 Hours in
RV-6's, just don't expect them to fly like a C-150. My comments are REAL and you
have to keep it real if you don't want to bend any metal.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
n5lp(at)warpdriveonline.c
PostPosted: Fri Aug 18, 2006 5:47 pm    Post subject: Electric Flaps option Reply with quote
with Me or My
Just goes to show that it doesn't take a whole lot of sense to become
a CFII/ATP. I don't believe in 5 kts over stall either, but 80 knots
over the fence is unsafe and stupid.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
http://n5lp.net
rv9jim(at)juno.com
PostPosted: Fri Aug 18, 2006 6:07 pm    Post subject: Electric Flaps option Reply with quote
Hi Tim,
The electric flaps are the way to go. I would use
"aircraftextras.com" flap controller if I was to do it again. I have the
three position system from Van's but it is a locked in system. The other
system is variable and you can set it where you want and how you want. I
spent a bit of time getting the fixed system to be "right". I would have
liked a simpler system and I think aircraft extras has that option.
Jim Nelson
dale1rv6(at)comcast.net
PostPosted: Fri Aug 18, 2006 6:20 pm    Post subject: Electric Flaps option Reply with quote
You might consider a small removable console. This works pretty well for us
(175 lbs and 120 lbs). picture attached. Do not archive.
Dale
 Filesize:  57.62 KB
 Viewed:  347 Time(s)
khorton01(at)rogers.com
PostPosted: Fri Aug 18, 2006 6:25 pm    Post subject: Electric Flaps option Reply with quote
> His
> with Me or My
I don't believe in 5 kts over stall either, but 80 knots over the
Let's keep in mind that every aircraft has different airspeed system
errors. ASI instrument errors differ, and sometimes they can be
quite large (I've seen reports of ASIs with 10 mph instrument
errors). And, many builders install something other than Van's
static ports, which can affect the static system errors, producing
several knots of airspeed error. Static and pitot system leaks may
also affect airspeed system accuracy. Thus, 80 kt IAS in one
person's aircraft might be exactly the same CAS as 70 kt IAS in
someone else's aircraft.
Optimum indicated airspeeds for various phases of flight need to be
determined by each builder, and are specific to that aircraft.
Kevin Horton
Ottawa, Canada
ceengland(at)bellsouth.ne
PostPosted: Fri Aug 18, 2006 6:34 pm    Post subject: Electric Flaps option Reply with quote
Tim:
And practicing '80 kts over the fence', don't expect to live if you have
an engine failure & have to land off-airport.
Please name the cfii so we'll know who to avoid. Wink
sbuc(at)hiwaay.net
PostPosted: Fri Aug 18, 2006 6:41 pm    Post subject: Electric Flaps option Reply with quote
Tim:
Well....don't know how simple my answers will be but I'll interject some
differing opinions.
Guess this is sorta subjective. The several armrests I have seen in RV's
are only about three inches wide (the width of the space between seat
cushions, and the pilots I polled seemed quite happy with the armrests.
My hangarmate put an armrest in his RV-6A and its still there after ~800
flight hours.
This situation is resolved by making the armrest easily removable.
One rationalization I have heard for the armrest to *prevent* bumping
posteriors. Wink
Tim wants an armrest because he has a throttle quadrant and wants to
brace his arm. Even though I don't have an armrest in my plane, if I
didn't have the cupholders between the seats I might have an armrest
with a little map pocket in it.
Some folks do.
Quite often, matter of fact.
Usually no, but then I hardly ever do hit the numbers. Wink
Kinda a moot point on a 6000' runway. But I guess if the engine stopped
running and the battery fell out of the plane just before a forced
landing in a little cow pasture, I would probably be wishing I had
manual flaps. But I find electric flaps to be quite satisfactory for the
frequent short, grass field landings I make. By the way, the flaps on my
plane are connected with a fused lead directly to the battery so the
flaps are available even if the master has been turned off.
Speaking of hitting the numbers or stopping in a short distance, it just
ain't gonna happen if you try landing an RV-6 after arriving at the
runway carrying 80 kts....
Hmmmmm, guess this one will depend on pilot experience and preferences, too.
I certainly have no intentions of tossing any flames, just offering a
different viewpoint. Its been so long since I flew a C150 I've forgotten
how they fly, but after nearly 800 hrs in my RV-6, I do have some
opinions on how *my* particular plane lands at various speeds and
configurations. Since my plane stalls at ~50kts indicated (but I'm
usually looking more at the LRI), I find "coming over the fence" at
70kts with the speed steadily decreasing to 55-60kts at touchdown works
very nicely when the wind isn't gusting. Any faster and the plane won't
three-point without skipping and a wheel landing is more apt to bounce
as well. When the tail drops and the wing incidence goes positive any
faster than 65 kts, the stubby little wings think they are being called
upon to fly!
Sam Buchanan
PostPosted: Fri Aug 18, 2006 7:04 pm    Post subject: Electric Flaps option Reply with quote
> <n5lp(at)warpdriveonline.com>
>> RV-6's. His
>> with Me or My
> do not archive
system errors. ASI instrument errors differ, and sometimes they
can be quite large (I've seen reports of ASIs with 10 mph
instrument errors). And, many builders install something other
than Van's static ports, which can affect the static system errors,
producing several knots of airspeed error. Static and pitot system
leaks may also affect airspeed system accuracy. Thus, 80 kt IAS in
one person's aircraft might be exactly the same CAS as 70 kt IAS in
Kevin Horton
Ottawa, Canada
But it sounds like this guy has a general rule not related to the
individual airplane.
Larry
Doug Gray
PostPosted: Fri Aug 18, 2006 7:09 pm    Post subject: Electric Flaps option Reply with quote
My kit was delivered with manual flap option and during the building I
have converted it to electric. Modifying the torque tube assembly was
no big deal. Just cut the three tubes and have a welder fit the three
steel 'brackets' in place.
It seemed a bit stupid to scrap the entire manual weldment for the sake
of three welds.
Of course you do need to find a capable aircraft welder to do the job.
I have found several jobs that needed to be done along the way so it is
good to know who to turn to.
BTW are your rudder pedals modified according to the Vans AD? If not
then get these welded at the same time.
Doug Gray
On Fri, 2006-08-18 at 22:06 -0400, James H Nelson wrote:
Hi Tim,
Jim Nelson
Doug Gray
PostPosted: Fri Aug 18, 2006 7:38 pm    Post subject: Electric Flaps option Reply with quote
At 80kts over the fence it's a wonder you can hit the numbers on the far
end of the runway. Perhaps the fence is a mile downwind.
I thought the rule of thumb was approach safety speed is 1.3 times stall
IAS in the landing configuration. I guess it is possible that the ASI
errors are so bad that IAS at flapless stall is >60kts.
Doug Gray
Goto page 1, 2  Next
Page 1 of 2
