k9hxt(at)sbcglobal.net Guest
Posted: Sun Aug 27, 2006 10:22 am Post subject: Oil temp |
After I re-built my cooler installation to increase input air opening, increased cowl exit opening, added "lips" on the bottom of cowl to add low pressure for exit, re-sealed all my baffles etc. Well, I checked the temp sender and it was OK(hot oil at 200°F) and then the last check was the Veritherm (200° oil). Naturally it was a vernitherm with only 3/16 " travel, which is not enough to seal off the port to get oil into the cooler. Replaced the vernitherm and oil is now 195°F !!!! It was as high as 225°F on 90°F days.
Larry
"LIMA TANGO SENDS"
| | - The Matronics RV6-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
