Russian Brass Exhaust Clamp bolts
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
ScottA
PostPosted: Mon Aug 14, 2006 10:55 am    Post subject: Russian Brass Exhaust Clamp bolts Reply with quote
I stripped a brass exhaust clamp bolt. Any reason why I can’t put an AN or stainless bolt in there with some high temp anti-seize on it instead?
So far it appears to me (about 40 hours on my M14) if you can keep the exhaust and intake port nuts tight and the segmented exhaust section from leaking there is no reason to have ANY oil mess at all on the M14 under the cowl.
Scott
Moose 174
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
