peter.rees01(at)tiscali.c Guest
Posted: Sat Jul 29, 2006 1:49 pm Post subject: Automatic Flaps up - Tri Gear |
Guys
I had imagined that many of you have already fitted such a system to your Tri-gear Europas but as I've had a couple of apprciative comments, implying that its not as common as I'd imagined, I thought I'd offer it to any who wants it.
G-MFHI is fitted with a button that when pressed, retracts the electric flaps to the zero stop - This is useful for cleaning up the airframe on the ground roll out or when climbing out. This bits easy - the tricky bit is preventing contention beteen the automatic system and the retained manual centre off switch. The system we have fitted retracts the flaps when the button is pressed but stops instantly if the down button of the manual flap switch is pressed.
If anyone wants the wiring detail and a technical explanation as to how it works, just let me know.
Peter
kheindl(at)msn.com Guest
Posted: Fri Aug 11, 2006 3:17 am Post subject: Automatic Flaps up - Tri Gear |
Peter,
I lost your original email. Could you please also supply me with your auto
flap details. Or could you write about it in the Europa Flyer ?
Many thsnks, Karl
| Quote: | From: "steve v." <s.vestuti(at)virgin.net>
Reply-To: europa-list(at)matronics.com
Subject: RE: Automatic Flaps up - Tri Gear
Date: Fri, 11 Aug 2006 11:03:28 +0300
Hi Peter,
can you please send me your 'auto flap retract'
drawings, i already have a pcb which accomodates two seporate
flap up/down push buttons with auto cancel & two seporate
sets of trim switches (stick & panel) with auto cancel ,
i want to see if i can accomodate your flap auto retract
in my layout,
thanks, steve vestuti #573 use s.vestuti(at)virgin.net
Visit EuropaOwnersForum http://www.europaowners.org/
DuaneFamly(at)aol.com Guest
Posted: Fri Aug 11, 2006 10:02 am Post subject: Automatic Flaps up - Tri Gear |
Peter and Steve,
Both your "auto" details may have peaked the interest of many other0 Europahiles. Making your wiring diagrams available to the list could help out0 many of your fellow flyers. I would be very interested in seeing them.0
Mike Duane0 A207A
Redding, California
XS Conventional Gear
Jabiru 33000
Sensenich R64Z N
Ground Adjustable0 Prop
Posted: Fri Aug 11, 2006 3:00 pm Post subject: Automatic Flaps up - Tri Gear |
Duane
Attached is my design for an auto up flaps mechanism. At first sight, it0 may appear both complicated and indeed, overcomplicated but reading the0 description should clarify whats going on and why there are a few more relay0 contacts than you may think are necessary. I guess that this has been installed0 on the aeroplane for about 100hrs and to date, has proved faultless.
Any questions, please feel free to ask.
Peter
 Download |
| Filename: |
autoflaps_(2).doc |
29.5 KB |
| Downloaded: |
324 Time(s) |
Posted: Sat Aug 12, 2006 9:15 pm Post subject: Automatic Flaps up - Tri Gear |
Hi Steve,
Thanks....yes, I would like a pix of your diagram. I'm into wiring my panel at the present time and I have been thinking about how to do the flap circuit.
Mike Duane
Redding, California
Jabiru 3300
