bcondrey
Posted: Fri Aug 11, 2006 1:40 pm Post subject: Nose Wheel Valve Clearance Solution |
I just found out that Matco will exchange the stock nose wheel that Van’s supplies with a different version that provides about 5/8” clearance from the fork. If you haven’t yet mounted a tire on it they will do this for only the cost of shipping!
If you have already mounted the tire they say you will likely mar the wheel removing the tire and therefore it can’t be sold as new. They can however sell you a new “valve half”, re-machine the back half and reuse the same bearings for about $55. Since you ship them the stock rim they can evaluate and if you were careful enough they’ll just do the exchange. Cost to purchase a complete wheel outright is about $125.
I have never been very happy about the valve stem clearance so I’m going to exchange mine while waiting for the new U-1023 spacers to come from Van’s and take care of everything at once.
Thanks to Dean Sombke for this tip! Hopefully others will take advantage of this offer from Matco before mounting the tire on their nosewheel.
Bob
rvbuilder(at)sausen.net Guest
Posted: Fri Aug 11, 2006 2:20 pm Post subject: Nose Wheel Valve Clearance Solution |
What exactly are they changing out? Is it the tire, rim, or both? Any specific contact name or secret handshake? Man I need to get moved and order my finish kit so I can see what everyone is talking about again!
Michael Sausen
RV-10 #352 Buildus Interuptus due to moving
Recent RV-10 Build Activity
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA)
Sent: Friday, August 11, 2006 4:37 PM
To: RV10-List(at)matronics.com
Subject: Nose Wheel Valve Clearance Solution
Bob
cehoffman(at)bellsouth.ne Guest
Posted: Fri Aug 11, 2006 2:29 pm Post subject: Nose Wheel Valve Clearance Solution |
Who is your contact at Matco?
Cal
bcondrey
Posted: Fri Aug 11, 2006 2:55 pm Post subject: Nose Wheel Valve Clearance Solution |
They are changing out the wheel assembly. You use thef stock tune and tire
When I called they transferred me to parts and the guy that answered knew exactly what I had and what I needed. Just tell them you're calling about the RV10 nose wheel
Bob
bcondrey
Just ask for parts
Bob
dlm46007(at)cox.net Guest
Posted: Fri Aug 11, 2006 3:19 pm Post subject: Nose Wheel Valve Clearance Solution |
you can search the list for a name and phone0 number that I provided when I exchanged mine about six months0 ago.
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Tue Aug 15, 2006 6:09 pm Post subject: Re: Nose Wheel Valve Clearance Solution |
I had copied a previous thread on this subject and saved it as a .pdf file.
I have attached it for those interested.
Kevin
40494
empennage
Matronics - nose wheel RMA info (valve stem clearance issue).pdf |
82.13 KB |
605 Time(s) |
wayne.e(at)grandecom.net Guest
Posted: Fri Aug 18, 2006 1:23 pm Post subject: Nose Wheel Valve Clearance Solution |
I just spoke with the people at Matco about returning my front wheel for exchange and they said, like a previous poster had said, they will take it back if it hadn't been mounted yet. The only difference from the last post is that there is a small fee for returning it. The fee is $18.30 plus you pay the shipping charges. If it's been mounted, like mine was but the plane had never been moved, they have to evaluate whether they can accept it back as new or if the have to repair it or not. I couldn't see a scratch on mine but I'll have to wait and see what they say.
I told the lady, Carolyn, that others said there was no charge if they hadn't been mounted yet and she told me that she has set up the receiving on all of these exchanges and they all were or would be charged the standard fee.
For what ever it's worth.
Wayne Edgerton #40336
front wheel off and going back
Posted: Fri Aug 18, 2006 1:48 pm Post subject: Nose Wheel Valve Clearance Solution |
I'm already deleting a whole bunch of stuff from the finish kit and I think this will be another item. No sense in paying for it to be shipped to me, returned, and have another handling fee and shipping fee assessed. Sure would be nice if Van's would just start using the correct part. I'm sure Matco has brought this up with them.
Michael Sausen
-10 #352
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Friday, August 18, 2006 4:22 PM
Subject: Re: Nose Wheel Valve Clearance Solution
Posted: Fri Aug 18, 2006 3:45 pm Post subject: Nose Wheel Valve Clearance Solution |
Since I was one of the first to exchange I believe there was a slight difference in list price. My total exchange cost $27 including freight IIRC.
