Tunnel Heat
flysrv10(at)gmail.com
PostPosted: Fri Aug 11, 2006 4:53 am    Post subject: Tunnel Heat Reply with quote
I insulated the tunnel, including the fuel lines (fear of vapor lock)
and found that it made absolutely NO DIFFERENCE in the radiating heat
from the tunnel. I will next try the Y hose split as suggested by
Van and really hope that I can get results.
RV10 Tunnel - 2
 Filesize:  111.08 KB
 Viewed:  272 Time(s)
