Seat Belts and ultimate G's
Tommy Walker
PostPosted: Tue Aug 08, 2006 3:59 pm    Post subject: Seat Belts and ultimate G's Reply with quote
The recent talk about Seat Belts and failure was very interesting.
I am reading AC90-89A (hey, I'm stuck in a motel in Starkville, MS, what do you expect?).
Anywho, I thought I would quote this from the above FAA doc.
"Each seat belt and shoulder harness mounting hard point should be built to the designer's specifications to ensure that it will hold the harness and pilot in the aircraft at the ultimate design "G" load specification, both positive and negative, for the aircraft."
I am adding the advisory as an attachment.
Food for thought.
Tommy Walker in Alabama
N8701 85%????
AC 90-89A AMATEUR-BUILT AIRCRAFT AND ULTRALIGHT FLIGHT TESTI.pdf
 Filename:  AC 90-89A AMATEUR-BUILT AIRCRAFT AND ULTRALIGHT FLIGHT TESTI.pdf
 Filesize:  797.99 KB
 Downloaded:  258 Time(s)
Tommy Walker
N25A - Anniston, AL
