sjhdcl(at)kingston.net Guest
Posted: Sat Jul 29, 2006 7:02 am Post subject: Cooling Blast tubes - Lycoming |
RV7A - IO360
I'm planning to install 5/8" blast tubes from baffling to fuel pump, 1 mag,
and alternator.
Routing and securing to baffling is easy but any tricks on securing the end
where the component is so the cooling
blast actually hits the fuel pump? Adel clamps stategically placed? Pics?
Steve
RV7A flying soon!
lhelming(at)sigecom.net Guest
Posted: Sat Jul 29, 2006 7:48 am Post subject: Cooling Blast tubes - Lycoming |
welchvincent(at)hotmail.c Guest
Posted: Tue Aug 01, 2006 8:49 am Post subject: Cooling Blast tubes - Lycoming |
Run a hanger or other stiff piece of wire through the inside of the blast
tube, bend it in any shape you like, then secure the hanger to the blast
tube with RTV. Clamp the tube to structure as required along the outside.
Vince Welch
RV-8A
| Quote: | From: "Steve & Denise" <sjhdcl(at)kingston.net>
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Subject: Cooling Blast tubes - Lycoming
Date: Sat, 29 Jul 2006 11:05:37 -0400
RV7A - IO360
and alternator.
Steve
RV7A flying soon!
daverv6a(at)gmail.com Guest
Posted: Tue Aug 01, 2006 11:50 am Post subject: Cooling Blast tubes - Lycoming |
Steve,
For the Mag I attached a clamp to engine and just aimed the tube at the mag.
For the Alternator, there isn't any convenient place to attach a clamp. I took a piece of wire, bent loops at each end the size of the outside diameter of the tube. Bent them 90 degrees, slipped them over the tube and then bent the wire so that it was "aimed correctly" I used RTV to keep wire in place.
I don'thave one to the fuel pump
Seems to work so far
Dave Burnham
On 7/29/06, Steve & Denise <sjhdcl(at)kingston.net (sjhdcl(at)kingston.net)> wrote: [quote]--> RV-List message posted by: "Steve & Denise" < sjhdcl(at)kingston.net (sjhdcl(at)kingston.net)>
RV7A - IO360
and alternator.
bertrv6(at)highstream.net Guest
Posted: Sun Aug 06, 2006 3:49 pm Post subject: Cooling Blast tubes - Lycoming |
Quoting LarryRobertHelming <lhelming(at)sigecom.net>:
Posted: Sun Aug 06, 2006 6:42 pm Post subject: Cooling Blast tubes - Lycoming |
Threaded brass rods will also work in place of the heavy wire. I have used
the bent rods with safety nuts or nuts with lock washers and the safety wire
with success for holding blast tubes in place. Larry in Indiana
