Greg.Puckett(at)united.co Guest
Posted: Mon Aug 07, 2006 7:10 am Post subject: lower cowl heat shield picture? |
g'day all,
I'm getting ready to install some of the Van's stick-on heat shield material to my lower cowl and would love to see a picture of where other have placed this stuff and found it successful at preventing burning/blistering.
My install is an angle valve I0360-A3B6D with Van's smooth bottom s-type cowl and Vetterman exhaust.
Greg Puckett
RV-8
N881GP
(first engine start and taxi yesterday)
Hopperdhh(at)aol.com Guest
Posted: Mon Aug 07, 2006 7:41 am Post subject: lower cowl heat shield picture? |
In a message dated 8/7/2006 11:14:27 A.M. Eastern Daylight Time,0 Greg.Puckett(at)united.com writes:
g'day0 all,
I'm getting ready to install some0 of the Van's stick-on heat shield material to my lower cowl and would love to0 see a picture of where other have placed this stuff and found it successful at0 preventing burning/blistering.
My install is an angle valve0 I0360-A3B6D with Van's smooth bottom s-type cowl and Vetterman0 exhaust.
Greg0 Puckett
RV-8
N881GP0
(first engine start and taxi0 yesterday)
[/quote]
Greg,
I don't have pictures, but here's what I did. First be sure you have0 painted the inside of the cowl with thinned epoxy. Then just put the foil0 down in large areas if the area is pretty flat and in smaller areas where0 it has curvature. In other words, it takes several separate0 pieces. I would say if you cover all areas that are within 60 inches of the exhaust system, you will have no problem. It isn't0very0 hard to do, actually.
Dan Hopper
RV-7A 200HP
randy(at)romeolima.com Guest
Posted: Mon Aug 07, 2006 8:52 am Post subject: lower cowl heat shield picture? |
Here's how I did mine...
http://www.romeolima.com/RV8/Cowl.htm#Heat%20damage
Basically just look inside the lower cowl and put the heat0 shield anywhere the exhaust is closer than about 6".
Randy Lervold
www.rv-8.com
www.rv-3.com
