matronics(at)cencula.com Guest
Posted: Sun Jul 30, 2006 3:01 pm Post subject: Elevator trailing edge bend radius (RV-7A) |
Greetings,
I'm building the jig to bend the trailing edges of the elevators on my RV-7A.
Does anyone know the correct bend radius for these trailing edges?
Mike
fstringham
Posted: Sun Jul 30, 2006 4:11 pm Post subject: Elevator trailing edge bend radius (RV-7A) |
Mike
I used an 1/8 inch wood dowel. I did tape the dowel in so it wood remain in
position. and I also taped the bottom edge of the elevator to the bending
break. I also couldn't believe how much force)it took to get the edge to be
straight/true/and the correct radius.
Frank (at) SGU and SLC finish................
| Quote: | From: "Michael D. Cencula" <matr onics(at)cencula.com>
Reply-To: rv-list(at)matronics.com
Subject: Elevator trailing edge bend radius (RV-7A)
Date: Sun, 30 Jul 2006 18:58:48 -0400
Greetings,
RV-7A.
Mike
Vanremog(at)aol.com Guest
Posted: Sun Jul 30, 2006 4:17 pm Post subject: Elevator trailing edge bend radius (RV-7A) |
In a message dated 7/30/2006 5:14:13 P.M. Pacific Daylight Time, fstringham(at)hotmail.com writes:
| Quote: | I did tape the dowel in so it wood remain in
position. |
No pun intended? Got wood? Do not archive.
-GV
rocketbob(at)gmail.com Guest
Posted: Sun Jul 30, 2006 4:32 pm Post subject: Elevator trailing edge bend radius (RV-7A) |
Mike, if you want a nice flying airplane in pitch feel use a 1/4" dowel. The tighter the radius, the heavier the airplane will be in pitch.
Bob Japundza
RV-6 flying F1 under const.
On 7/30/06, Michael D. Cencula <matronics(at)cencula.com (matronics(at)cencula.com)> wrote: | Quote: | --> RV-List message posted by: "Michael D. Cencula" <matronics(at)cencula.com (matronics(at)cencula.com)>
Greetings,
Hopperdhh(at)aol.com Guest
Posted: Sun Jul 30, 2006 6:28 pm Post subject: Elevator trailing edge bend radius (RV-7A) |
Mike,
On Drawing 4pp it shows 3/32 as the minimum bend radius. This was for .020 skins when I built mine about 5 years ago. Actually, I didn't put anything in to maintain that radius. But I did have a little trouble with the stiffeners limiting the travel. As a result the skins are not as smooth as they could be. I made my "brake" out of some old door jambs and hinges. It seems like it would be hard to keep a dowel in position. Let us know how it works out, please.
Dan Hopper
RV-7A
In a message dated 7/30/2006 7:03:38 P.M. Eastern Daylight Time, matronics(at)cencula.com writes:
Mike |
