OSH Engine Info
bcondrey
PostPosted: Thu Jul 27, 2006 2:15 pm    Post subject: OSH Engine Info Reply with quote
As I noted in a prior post there really is very little here in the way of engine news. Several people have expressed interest in pictures so I've attached a collection.
At the risk of repeating myself, here are a few comments about what I've seen so far.
EMag/PMag: Hoping to flight test 6 cylinder version in the spring and have them at OSH next year. No other info available but they appear to be getting tired of being asked about it.
Mistral: Engines look good but no real delivery info. Big thing they were pushing is that each cylinder has dual injectors "in case one fails". Pictures attached of both models along with their rotor display.
Innodyne: Don't even have their own booth this year - they seem to be doubled up with one of the bush plane kit manufacturers. Picture attached of their entire display along with a closeup of the nose section of the engine with rust on the prop flange.
Deltahawk: They are displaying inside and talking about deliveries "next year". No picture attached.
Suburu: Only engine is the one in the demo plane. I asked about the RV-10 setup and they said "next year". Picture attached of their display space.
I also took a picture of yet another possibility but you might have to extend the cowl a bit. Engine is compression ignition and generates 350 HP.
 Filesize:  62.36 KB
 Viewed:  482 Time(s)
 Filesize:  66.77 KB
 Viewed:  422 Time(s)
 Filesize:  67.99 KB
 Viewed:  450 Time(s)
 Filesize:  40.93 KB
 Viewed:  411 Time(s)
 Filesize:  58.5 KB
 Viewed:  429 Time(s)
 Filesize:  63.22 KB
 Viewed:  448 Time(s)
 Filesize:  57.3 KB
 Viewed:  448 Time(s)
 Filesize:  85.46 KB
 Viewed:  438 Time(s)
pascalreid(at)verizon.net
PostPosted: Thu Jul 27, 2006 5:03 pm    Post subject: OSH Engine Info Reply with quote
Thanks for the info and pictures.
The more I here about the "other" engine options the more Lycoming sounds
like a better choice.
At least I know it's been tested and is shipping!
Appreciate the comparo.
Pascal
toaster73(at)earthlink.ne
PostPosted: Thu Jul 27, 2006 6:15 pm    Post subject: OSH Engine Info Reply with quote
I'll add another thanks for the updates... How about ECI's experimental 540?
Any new news on that?
Chris Lucas
#40072
bcondrey
PostPosted: Fri Jul 28, 2006 9:39 am    Post subject: OSH Engine Info Reply with quote
Just talked to them - they say it should be ready to show and ship by next summer at OSH.
Sent from my BlackBerry Wireless Handheld
rvbuilder(at)sausen.net
PostPosted: Mon Jul 31, 2006 7:01 am    Post subject: OSH Engine Info Reply with quote
One thing I will add about the Mistral is that they did tell me that the
smaller two rotor engines are available now and their current goal is
certification. Three rotor model was probably next year. YMMV. The
smaller two rotor turbocharged 230HP would probably be a good fit for
the -10.
Michael
PostPosted: Mon Jul 31, 2006 7:54 am    Post subject: OSH Engine Info Reply with quote
There is already one person in Denmark putting the 230 in his RV-10. If you
look at engine it gives his opinion of the factory tour, if you look at
"updates" you'll get the engine delivery status.
http://www.rv10.dk/rv10/rv/defaulte.htm
PostPosted: Mon Jul 31, 2006 8:30 am    Post subject: OSH Engine Info Reply with quote
Interesting read. Update is a little old so I wonder if he has received
an engine yet? Based on some of the comments from other guys that
visited their tent, I must have got lucky as the guy I talked to was
fairly chatty.
Michael
LloydDR(at)wernerco.com
PostPosted: Mon Jul 31, 2006 12:27 pm    Post subject: OSH Engine Info Reply with quote
Did they have the Dyno reports and fuel flow proof that you have asked
for from others?
Dan Lloyd
40269 (N289DT)
Tongue in cheek comment
PostPosted: Mon Jul 31, 2006 12:52 pm    Post subject: OSH Engine Info Reply with quote
Dunno, already paid for my engine so I was just collecting data for
the other guys. Smile
One thing to note as long as this came back up is Mistral has no FWF
for a -10.
Stopped by the campsite a couple times but kept missing you. Should
have swapped numbers, next year we will just have to double up on the
drinking!
Michael
