Sean Blair
Joined: 09 Jan 2006 Posts: 39 Location: Colorado Springs
Posted: Mon Jul 24, 2006 6:23 pm Post subject: Throttle quadrant |
When installing the throttle quadrant, are the cables routed through the firewall recess in the stock location? If not, where? I think I heard they don’t take the same route and of course already enlarged the stock holes per the plans. What’s the fix if necessary?
Once again…..thanks!
Sean Blair
#40225
_________________ Sean S. Blair
#40225
N967SB (reserved) |
Tim(at)MyRV10.com Guest
Posted: Sat Jul 29, 2006 3:35 pm Post subject: Throttle quadrant |
When I did the quadrant I installed the cables in a "V" shape. The
two outer holes at the top, and then one centered below. I used
eyeball vents. The reason for the V is just that the original
3 holes are too close together to do 3 with eyeballs. If you already
enlarged them, then drilling the eyeball holes may make a mess of your
firewall like I did. Just rivet a patch in place that's big enough
to accomodate all 3 and drill them again and you should be fine. I
had a chewed up firewall from holes running together, so I had to
clean it up and put in a patch as above, which worked just fine.
Sean Blair wrote:
| Quote: | When installing the throttle quadrant, are the cables routed through the
Sean Blair
#40225
