Jeff Bearden
Joined: 31 May 2006 Posts: 4 Location: St. Augustine, FL
Posted: Sat Aug 05, 2006 1:36 pm Post subject: is this spray gun ok? |
want to know if my spray gun is usable.
i set up a clean air line for spray priming, and then bought an el cheapo spray gun from hft. the gun has some oil on the internal parts apparently for lube or preservation from the manufacturer.
is this normal? can i clean the gun maybe by spraying some mek or alcohol through it?
thanks for any newbie education...
jeff
_________________ -Jeff Bearden
St. Augustine, FL
RV-8 #82563
perfeng(at)3rivers.net Guest
Posted: Sat Aug 05, 2006 6:09 pm Post subject: is this spray gun ok? |
Jeff,
Just use some wash thinner and run it through the gun. I'm assuming that
it's a siphon type gun (looks like a Binks 7) Best is to break down the gun
as you would for cleaning.
Jim D.
DO NOT ARCHIVE
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Sun Aug 06, 2006 1:26 am Post subject: is this spray gun ok? |
Yes, I've recently broken in a couple of new guns and can advise that
they were assembled with quite a bit of oil. Clean it well before first
priming session. Perhaps a trial paint run to sort out settings before
pointing at some airplane parts would be wise.
Doug
On Sat, 2006-08-05 at 14:36 -0700, Jeff Bearden wrote:
jeff
-Clam
http://forums.matronics.com/viewtopic.php?p=52626#52626
